To all with the notorious Rough Idle....
Old Mar 10, 2008 | 10:56 PM
kneeland11's Avatar
I have been thinking about this since I bought my truck, and I have actually had it to the dealer twice for this. It drives me nuts that my brand new truck idles rough. It isn't bad enough that it is a miss or anything, it just acts like it has an aggressive cam. I had my buddy open the hood on his tundra and the engine shake is aboutt he same on the engine, but his Tundra idles flawlessly inside the cab. Does anyone make an aftermarket set of motor mounts that would eliminate this engine vibration? Any other suggestions?
Old Mar 11, 2008 | 01:23 AM
phiberoptik957's Avatar
I too am interested in this. This is my second F150 had an 04 and now an 08.
Because I dont know as much as I would like to know about the mechanics of automobiles, the rough idle makes me think maybe theres something wrong....
Old Mar 11, 2008 | 01:39 AM
Tylus's Avatar
4.6 right? the rough idle is due the tune. Ford is trying to squeeze all the MPG out that it can. so the motor idles at lower RPM and runs a little leaner.
my Mustang's 4.6 does the exact same thing...I know it sucks, but it is normal
all I can think is you could try using a programmer to bump the A/F mix up slightly and raise the idle about 50-100 rpm
Old Mar 11, 2008 | 06:59 AM
cranehand's Avatar
I have a 5.4L and have the same problem.I took it in, they said yup it idles rough but couldn't tell me why and no idea how to fix it
Old Mar 11, 2008 | 09:03 AM
kneeland11's Avatar
5.4 here too. I am just wondering if anyone thinks there is a way to design motor mounts that isolate the idle more. The Tundra I looked at had about the same amount of engine shake, but was completely isolated by the motor mounts. I have tried bumping the idle, different tunes, different fuels, no difference.
Old Mar 11, 2008 | 09:52 AM
ford2004F150's Avatar
Clean your TB.
Did wonders for mine.
Old Mar 11, 2008 | 01:57 PM
mikebaby's Avatar
What dealer did you go to?
mikebaby
Old Mar 12, 2008 | 12:35 AM
kneeland11's Avatar
mikebaby
First Germain, they aknowledged the rough idle, but failed to fix it, then Krieger and they claimed they couldn't reproduce the problem. It kills me. every day I am annoyed by this rough idle. I cannot even sit in my truck with it in park with the engine running. I have to shut it off because it bothers me so much. Maybe I'm just ****, I don't know.
Old Mar 12, 2008 | 12:44 AM
duece212's Avatar
My 4.6 truck has a rough idle I've noticed as well. Its noticeable but not a big deal to me.
Old Mar 12, 2008 | 12:46 AM
johnfields20's Avatar
Mine has a rough idle to and it has the rearend clunk and it has some highway vibrations. But hey its a truck not a cadillac.
Old Mar 12, 2008 | 09:19 AM
JesseRohr's Avatar
Buy a tuner and it will go away.
Old Mar 12, 2008 | 09:24 AM
openclasspro#11's Avatar
pimprohr- was those hp numbers on the 33's and what were the mods
Old Mar 12, 2008 | 10:14 AM
mikebaby's Avatar
I think you are missing the point. He should not have to buy anything, the issue shouldn't exist, and because it does, Ford should make it right.
mikebaby
Old Mar 12, 2008 | 10:20 AM
CRF250rider1000's Avatar
How bad are the vibrations? It could be your parking brake sticking I know mine did once and it shook that truck like CRAZY! I unstuck it, now I'm just waiting till the weather warms up to pull the rotor off and fix it.
Old Mar 12, 2008 | 10:43 AM
kneeland11's Avatar
mikebaby
Thats the thing, I do have a tuner. It does it on eevery setting, including stock. I tried bumping the idle and still there. Maybe the truck is running a little lean to save on fuel economy.
