F150online Forums
F150online Forums (https://www.f150online.com/forums/)
-   2004 - 2008 F-150 (https://www.f150online.com/forums/2004-2008-f-150-80/)
-   -   Calling on 4x4's for help, need pic of tow hooks installed. (https://www.f150online.com/forums/2004-2008-f-150/321448-calling-4x4s-help-need-pic-tow-hooks-installed.html)
ddgarcia05 Feb 16, 2008 08:08 PM
I would really appreciate if anyone having a 4x4 could snap a picture of how there tow hooks look from under the truck. I bought a set of tow hooks with all the bolts and nuts I just need a picture so when they arrive I can install them.
blackjack8900 Feb 16, 2008 08:13 PM
If you can wait till tomorrow I will get a pic for you when I pull my truck in the garage.
ddgarcia05 Feb 16, 2008 08:22 PM
Yeah, sounds good. I dont get my parts until Monday or Tuesday. Thanks if you want email me the pictrues to ddgarcia05@aol.com:banana: :banana:
Tylus Feb 16, 2008 10:16 PM
look at my gallery
http://www.ford-trucks.com/user_gall...id=164860&.jpg
sorry, it ain't the greatest. I don't have them installed anymore
ddgarcia05 Feb 16, 2008 10:27 PM
Originally Posted by Tylus
look at my gallery
Thanks for the picture give me an idea of what I have to cut, but I was looking for a picture from under the truck exposing the bolts and how it's attached to the frame.
LsuSuperCrew Feb 17, 2008 01:23 AM
I added the tow hooks to my truck, the tow hooks mount on the bottom of the frame flat against it. The nuts for the bolts are actually attached to each other, they slide inside the frame rail. The hard part is getting the nuts to line up with the holes inside the frame rail then starting the bolt. They way I did it was to place the nuts in the frame rail then start the back bolt, once it was started then I put the tow hook on. The back bolt on the tow hook has a hole to fit the head of the bolt through then it slides back. Once you get the tow hook on you can start the front bolt. It's not as bad as it sounds and it should be a little clearer once you see how the parts are made.
Tylus Feb 17, 2008 01:51 AM
yeah, it ain't so hard to install them.
laying on your back and looking up, you'll see 2 holes in the bottom of the frame rail. on the inner side of each frame rail there is a slot big enough for 2-3 fingers.
slide the bolts into that slot and drop them down through the holes. you can then thread on the nuts and tighten up the tow hooks. it's a little tedious, but easy to do
Stealth Feb 17, 2008 02:32 AM
I put them on my 2wd when I put on my guard and took them off when I sold my guard. No problem to do.
blackjack8900 Feb 17, 2008 06:26 PM
Here you go
[IMG]http://i221.photobucket.com/albums/d...0/DSCF1662.jpg[/IMG]
[IMG]http://i221.photobucket.com/albums/d...0/DSCF1663.jpg[/IMG]
[IMG]http://i221.photobucket.com/albums/d...0/DSCF1661.jpg[/IMG]
ddgarcia05 Feb 17, 2008 06:45 PM
Awesome thanks, this really helped and was exactly what I was looking for. :banana: :banana: :banana:
