Intake issues
Old Jan 10, 2008 | 03:40 PM
SIG7FX4's Avatar
Angry Intake issues
my uncle and i were trying to install a K&N intake on his 06 5.4 and we broke two of the four bolts that hold the throtlebody in place. how difficult or is it possible to get out the broken bolts and replace them.
Old Jan 10, 2008 | 07:40 PM
07 Crew's Avatar
The best thing to do is try to get a easy out the size of the bolt and try to tap into it and back the broken bolt out. They shouldn't be in there that tight unless they rusted for some reason? Make sure that you stuff a rag in the opening of the intake so no dirt of metal shavings go down the intake. It's a bad bind to be in but I hope it turns out alright for you.
Old Jan 11, 2008 | 12:54 PM
SIG7FX4's Avatar
alright thanks for the advice i will try that.
Old Jan 11, 2008 | 06:13 PM
openclasspro#11's Avatar
why remove the tb?
Old Jan 11, 2008 | 09:08 PM
2006M50B's Avatar
Originally Posted by openclasspro#11
why remove the tb?
If i remember correctly from when I installed mine you have to remove the TB to put in an elbow, then mount the TB to the elbow to line up with the intake tube
Best of luck getting it running
Old Jan 12, 2008 | 12:10 AM
azmidget91's Avatar
kind of odd that they would have you move your tb when all the other kits use a elbow on top of the tb instead of under it
Old Jan 12, 2008 | 11:01 AM
2006M50B's Avatar
odd yes-but im not the engineer so I just did as the instructions said to do
Old Jan 12, 2008 | 11:20 AM
xlint1's Avatar
The elbow before the throttle body is basically a TB spacer. More performance.
