4x4????? HELP
To shift into to 4wd hi, you can shift on the fly of slow speeds, to shift into 4WD-LO you gotta come to a full stop, put foot on brake, place trans shifter into neutral & shift into 4WD LO.......
It doesn't hurt it... but I wouldn't suggest doing it anything above 20 mph. Even then, out of courtesy, any of my friend's trucks that I drive during the winter if they have the electronic 4x4, I usually pull over to a complete stop then click it in the 4x4. I don't wanna bust their truck on them... then I'll never be able to use it again.
4x4 low you need to make sure gear selector is in N, at a stop, and then select 4x4 low.
Originally Posted by gibsonplayer45
My friend Is shifting his 2007 f-150 into 4x4 while driving down the road. I told him he is an idiot. can he do that without damaging the truck??
Depends. If he's gunning it on ice and his rear tires are spinning and his fronts aren't and he puts it into 4x4, he's gonna get a big boom.
If he's just driving down the road and puts it into 4x4, no damage will be done.
Too many people
think 4WD is the same as AWD. It isn't.
You should not engage 4WD unless you are in snow or mud. If you drive in 4HI on pavement you will subject your drivetrain to a lot of stress.
Some of you guys are clueless. Pulling over to put it in 4x4 hi?
Read your manual. 4x4s have been switchable on the fly for quite a few years now. You will do no damage. And yes there is a need for 4x4 to be engaged at highways speeds.
Never ceases to amaze me the city boys who buy these trucks w/o a clue. But I guess the questionsare being asked so you can learn.
If the 4x4 system is so fragile that you can't shift over to it when conditions warrant, what's the point of having it at all?
If you are turning sharp in a parking lot you should turn the 4x4 off. Its the big cranks of the wheel that start to get it to bind. A slight turn is generally not going to hurt it.
Yeah that slush is very dangerous. 4x4 helps a bit but that is the one driving condition that always gets me nervous.
I use 4x4 everyday because of ice/snow and have no problems. Yeah, it'll bind when you turn, big deal. Both tires are trying to go the same speed. I've driven up to 70 or so in 4x4 with not problem and driven many miles at 55/60 in 4x4. My 4x4 still works so it must not be too fragile.
Originally Posted by Moltenice
doesnt 4lo have a sensor that will keep it from engaging unless you stop and put it in neutral? Since it is electronic engagement, it is easy to put sensors that will prevent harmful activations.
