Higher output lights part #
Old Nov 15, 2007 | 06:28 PM
TX-FX-4's Avatar
Got an 05 F150. Wondering if anyone knows of some higher output replacement bulbs. Brand and part number would be extremely helpful. T hanks
Old Nov 15, 2007 | 06:32 PM
mSaLL150's Avatar
biXenon HIDs
installing mine next week.
Old Nov 15, 2007 | 08:37 PM
TX-FX-4's Avatar
whats the model or part number on those?
Old Nov 15, 2007 | 08:48 PM
mSaLL150's Avatar
the bulb type/size for our trucks is H13 / 9008.
the biXenons i got are off ebay, $150 shipped.
any of these will work...they put out 3x more light then stock headlights, and replace both your lo and hi beam bulb.
http://stores.ebay.com/HID4U_H13-900...QQftidZ2QQtZkm
the difference between them is the beam color, ranging from stock to white to blue to more purplish. i went with the 6000k, which is basically a pearl white with small tint of blue.
keep in mind, although you most likely will not get sited for it unless you are flashing people or abusing the high beams in town, these *are* illegal.
Old Nov 17, 2007 | 10:09 PM
TX-FX-4's Avatar
Thanks for that info. I was reading about some problems with the Hi- low beams when the lights are activated. Somewhat of a malfunction with this particular lights?. Or is there a particular manner of connection to prevent any issues? blue-low beam, orange- high beam, white ground is something I had read, but is there an relay or additional item needed to prevent problems? Thanks
