FireStone Ride Rite Install
Not exactly. Are you referring to a slammed/bagged truck that will lay frame? That is a totally different setup but same principle. An air bag in between the axle and frame to alter the height/load capacity with different pressure of air.
i just pruchased a set of these waiting for them to come in.. if i keep the bags at 5 pounds will it maintain the stock height? i leveled the front and when im not towing id like to keep the back level like it was? also how do you know how much psi you should inflate in the bag when you have a trailer on the back? is there a scale?
