Low Temp Thermostats
Old Oct 29, 2007 | 07:59 PM
05F1FIDDY4x4's Avatar
Anyone replace the stock thermostat with an aftermarket Low Temp Thermostat? Have you noticed any performance gains? What brand did you get? Looking at the Jet Low Temp Thermostat which is $15.
Old Oct 29, 2007 | 08:07 PM
Bootleg837's Avatar
I put a 180 stat in but its not like factory, factory one has a two stage stat any ways my fastest time to date was with the stock stat
Old Oct 29, 2007 | 08:45 PM
osbornk's Avatar
If you change from the stock thermostat, you will confuse the computer and will result in the wrong fuel mixture. I suspect the fuel mixture would be rich and you would burn more fuel and maybe foul up the plugs and/or the converter.
Old Oct 29, 2007 | 09:12 PM
do a search on the subject. It has been pointed out that these newer engines need at least 195 degrees to be efficient and actually perform better at around 200 to 205.
