Help with u joint removal for an 04
Old Oct 12, 2007 | 02:58 PM
chazf150's Avatar
I`m ready to replace u joints ,3 total . But I`m stumped, I see no C clips of any kind on these joints. Is there some special tool or are they pressed in. I`ve done this b4 on my chevy!
Did find a thread saying that 2004 were permanent with the diff. Is this true?
Old Oct 12, 2007 | 03:15 PM
Non serviceable. When I had my driveshaft replaced the u joints in it had c clips. So They took out one DS with non serviceable u joints and put in another with serviceable u joints.
Old Oct 12, 2007 | 05:10 PM
chazf150's Avatar
^ ? Do you think it would be under warranty ?
How much for a new drive shaft ?
Old Oct 12, 2007 | 06:48 PM
Should be, I had mine changed because of a driveline vibration under a TSB. If you're under warranty, ask your dealer.
Old Oct 12, 2007 | 07:21 PM
chazf150's Avatar
I have about 8000 miles left on warranty. But will they cover it with my lift and oversized tires ?
Old Oct 12, 2007 | 08:47 PM
Only one way to find out.
Old Oct 12, 2007 | 08:58 PM
chazf150's Avatar
thanx Stealth, For the info. I`ll give it a try on monday
