recon 3rd brakelight help
Old Oct 5, 2007 | 08:34 PM
07screw's Avatar
I installed the unit last Mon and now its leaking inside the cab?
have any of you had this problem?
should i just seal it with silcone or some sort of automotive sealant
what should i do?
Old Oct 5, 2007 | 09:09 PM
RUSS04's Avatar
what should i do?
I never had a problem with after market 3rd brake lite I replaced my sons with a hella Replaced mine twice with no problems Did you use the washers that fit on the screw ? This is what i did Take third brake light off Clean around where gasket will seal around roof Mount 3rd brake lite make sure you installed rubber washers on the screws Screw in the the the brake lite holding down on the brake lite Tighten till snug while still putting pressure on the brake lite I gave both screws 1 turn to make sure it sealed I hope this will help you out
Old Oct 6, 2007 | 09:08 AM
07screw's Avatar
my stock one did not have rubber washers and the new one did not come with one
Old Oct 6, 2007 | 09:14 AM
ThumperMX113's Avatar
Mine didn't have those too but it's not leaking either. I'd get some clear RTV sealant or silicone and just clean both surfaces and lay a THIN bead down. Let it dry for a little while before going driving and it should be A-OK!
Old Oct 6, 2007 | 08:31 PM
AirborneRacer's Avatar
No problem with mine either and its been on for about 1 1/2yrs and many passes thru the laser wash. I did put RTV in the holes where the screws go(over the screws actually) just to play it safe.
Old Oct 29, 2007 | 02:28 AM
NOLES187's Avatar
what does RTV stand for?
Old Oct 29, 2007 | 03:34 AM
CANES676400's Avatar
not exactly sure but its a silicone sealant
Old Oct 29, 2007 | 06:19 AM
Monstermile's Avatar
RTV: room temperature vulcanizing
Basically it means it cures at room temperature w/o using heat or chemicals.
