what do you have?
How do you like it?
thanks!!
JimIII
How do you like it?
thanks!!
JimIII
A 4/6 would need a notch for sure. I curently have the 3.5"/5" DJM setup. Love the way it looks and rides, except when I hit a large bump and the rear end bottoms out on the frame. I can still tow, but like I said on large bumps the rear will hit the frame.
Thanks, Anyone with a 2/5 or 3/5 and pics???
I have a 3/5 on my 03 and i love the looks. it could ride a little better, but i think that is just the worn out shocks b,c they are maxed out b.c of the drop
Quote:
2/5's look to me the rear sits lower then the front...Originally Posted by JimIII@jdm
Here is mine with the DJM 3/5 running 20"x8.5" centerline wheels with 295/45/20 General's
ALso the picture in my sig is with the same drop with the factory 17" wheels running 275/50's
I also need to say with the latest 20" wheel tire combo I have I do rub on big dips in the road while at high speed.
Originally Posted by FATHERFORD
2/5's look to me the rear sits lower then the front...Here is mine with the DJM 3/5 running 20"x8.5" centerline wheels with 295/45/20 General's
Truck looks great!
Our truck is going to have the 23" saleen wheels and they are 32.5" tall overall
I'm going to have to agree. Staying with those 32.5" tall tires, 2/4 would be as low as you would want to go.
We are going to us a Saleen front 2" spring rear 3" leafs and DJM rear shackles 1.5" combo...we'll see how it works!!
do'nt go any lower than 2/4 with a 32.5" tire, my 275/45-22's are 31.8 tall and they rub up front when I hit the huge bump at high speed (double posted limits)... or when i'm doing 75 around corners that have a 25mph speed limit. it'll be fine until you start driving crazy
when i'm doing 75 around corners that have a 25mph speed limit. it'll be fine until you start driving crazy[/QUOTE]
Friggin nuts .......
3/5" drop here with 22's on 31.5" tires. i agree with others saying a 4/6 or even a 3/5 would probably be too low for 32.5" tires...
heres mine
heres mine
2 years ago I had a 2/5 GroundForce kit with 305/45/22 = 32.8
