Need Rotor Removal Help
Old Sep 1, 2007 | 04:58 PM
keith61760's Avatar
Originally Posted by wrench007
You may need a BFH to get it off, just be careful. Here is the front. If you need pics of the rear let me know,,Good luck should be an easy job. Tap,tap, spin, tap some more, keep rotating it. Put some antisize on the hub so next time it will fall off in your hands.
Wrench007-Where did you get the diagram from? Is this from a book or a disk?
Old Sep 1, 2007 | 06:08 PM
wrench007's Avatar
Kieth, I have the 2004-2005 Service information DVD from ford. I got it off e-bay for 10 bucks. Only problem is that I have to set my computer back to 2004, no biggie, works great. Take care
Old Sep 4, 2007 | 11:45 AM
GotBeer's Avatar
For the rears make sure you dont have the ebrake on. Nothing more frustrating than hammering on it for an hour only to realize that it is the ebrake holding the thing on.
Old Sep 4, 2007 | 12:04 PM
05supercrew's Avatar
Mine were rusted on. 5 lbs sledge hammer and about 1/2 hr each side in the backs. The fronts came right off.
Old Sep 4, 2007 | 12:28 PM
MGDfan's Avatar
Pm
Y'all need to do some preventative maintenance.
Before reinstalling rotors apply a very thin coating of hi-temp anti-seize to the hubs ( around but not on, the studs). I repeat - a VERY thin coat - you don't want this stuff migrating onto your rotor surfaces lol.
No more stuck hubs - ever.
Ideally, you should do this asap when the truck is new, no later than, say, your first tire rotation.
One less problem down the road - you could say it's along the same vein as popping out your plugs when still new to apply hi-temp nickel AS.
'Course this only applies to folks who can actually spell PM
Old Sep 4, 2007 | 01:01 PM
khendrix2374's Avatar
So MGD,
You boght your truck and took the rotors off and did this when it was new? Yeah right. You can say you did but I still won't believe you. LOL
Old Sep 4, 2007 | 01:56 PM
MGDfan's Avatar
Originally Posted by khendrix2374
So MGD,
Yes, I did.
Because my old 2000 had stuck rotors.
I learned from my mistakes - what's wrong with passing that along?
BTW - I did the plug thing, too.
Believe what you wish .... do not care.
Old Sep 4, 2007 | 01:57 PM
last5oh_302's Avatar
Oh, you care!
Old Sep 4, 2007 | 02:02 PM
MGDfan's Avatar
Originally Posted by last5oh_302
Oh, you care!
No - not really. Why would you think otherwise?
Old Sep 4, 2007 | 02:11 PM
Originally Posted by MGDfan
Nor really. Why do you think otherwise?
It's important that you care. It's what makes you, well, you!
I care!
Old Sep 4, 2007 | 02:28 PM
MGDfan's Avatar
Well - the only thing I care about is, my AssClown detector is on the fritz again.
It should have picked up on this latest AC who, instead of just taking (or leaving) hard-won good advice in the positive manner for which it was intended, decided on a banal retort.
Damn windoze software.
Old Sep 4, 2007 | 02:33 PM
Chill out. I was just kiddin' with ya.
Old Sep 4, 2007 | 06:33 PM
Hahahaha!! I leave mine off, because it detects me, and the alarm drives me nuts.
BTW, I also don't believe you anti seized your hubs
Old Sep 4, 2007 | 07:06 PM
ThumperMX113's Avatar
Why are you so annoying?
Old Sep 4, 2007 | 07:12 PM
It's a gift
