Sylvania Fog Lights for 2004
This past weekend I upgraded to the Sylvania Headlight, turn signal, and fog lights. But I uncovered an issue with the Sylvania website... they list 2 different versions of the fog light bulb (guess which one I got)
http://www.sylvania.com/ConsumerProd...RG-Results.htm
I bought the H1ST bulbs... but the do not fit my truck. Luckily AutoZone would exchange them for me (I had already opened one bulb) and let me get the 9145ST bulbs.
If you have the Rectangular Fog Lights then be sure to get the 9145 bulb. I'm just guessing here... but maybe the H1 bulb is for the round fog lights? Did any of the 2004 trucks have the round headlight?
If you want to be totally sure, just check your old bulbs before you go!
Originally Posted by www.sylvania.com
2004 FORD F150
Fog/Driving light
9145
9145ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
H1-55W
H1ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
H1XV XtraVision Halogen - The Brighter Light
Fog/Driving light
9145
H1-55W
Don't know why you would have gotten the H1ST bulbs in the first place. They (as you found out) will not fit. Yes, the 9145ST is designated in the catalog and will fit right in that housing. What many folks don't know is that a 9005ST also fits - and has about twice the light output. Many of us have swapped out the stockers for these. One additional hint - go for the Silverstar Ultras instead of the regular Silverstars. The regular ones are about a 12 month bulb - if you're lucky. The Ultra's are supposed to last longer.
Sylvania lists both bulbs. Crazy me, I believed them... thinking that they would fit.
I just wanted to warn others that might go off the manufacturers word. I did a quick search and didn't see where anyone talked about it.
...What many folks don't know is that a 9005ST also fits - and has about twice the light output...
I thought there were posts some time back of folks complaining that the 9005ST affected the lense on the fog light due to the exccess heat of the brighter bulb???? Could be wrong though, don't remember exactly....
The owners manual has all the right bulb sizes for your truck... I used that reference when i did the SilverStar upgrade... Although I did 9005 for fogs so I had a little extra light
You'll love Sylvania though
Edit:
The lenses will melt IF you leave them on for long periods of time... but a 30 minute drive won't kill the lenses...
Edit:
Originally Posted by DTheobald
Edit:
WOW, that sounds like a pretty risky gamble then....Why would you risk damage to the lenses and the harness? I'll stick with the normal output bulbs.
Seriously, who monitors how long they've driven so they know if they need to shut off the fogs to prevent damage to the lenses....
Originally Posted by kingfish51
For both the H13/9008 and the 9145, they do not make an Ultra yet.
The "Ultra" ? Is this a newer, "better" Silverestar? If it's supposed to be better, how so?
He told me there was minimal difference in brightness but a substantial difference in light output.
The "melting lens" issue seems to be more common on the '06 and up fogs which have a smaller, round housing. (Less place for the additional heat to dissipate.) I have the '04 - '05 fogs with the larger, rectangular housings and have had absolutely no problems.
As for the harness problems (notice how all problems seem to involve melting something?) , I think you'll find that most folks who had that problem got a little silly with wattage. The 9005 Silverstars draw only about 20 watts more per bulb than the 9145's. This doesn't seem to be enough to cause problems. If you plant 100 watt bulbs in there, you're going to melt everything!
Originally Posted by Grubrunner
I contacted Steve at Sylvania about this about a month back as I was interested in upgrading and curious.
I meant to say: He told me there was minimal difference in brightness but a substantial difference in light's life.
My 06 melted the center part of the lense. Then it started to screw up the rest of my lights... ie couldnt use brights, and would shut off standard lights. Removed and had no problems.
