BAJA150 LIFTED WITH PICTURES... finally.
Originally Posted by baja150
I think the bumper/valence are higher off the ground on 2004-2005 trucks. I noticed this when I was comparing how much of the skid plate you can see on my truck and how much you can see on a 2004; granted the 2nd picture is taken from a lower angle, but I still think the 2004-2005 bumpers are a little higher.
Ok I took some measurments.
GROUND to BOTTOM OF VALENCE: 19.4"
GROUND to TOP OF VALENCE/BOTTOM OF STEEL BUMPER: 24.7"
GROUND to TOP OF STEEL BUMPER: 33.9
GROUND to HEAD OF TOW HOOK BOLT: 24.8"
Based on the ground to bumper and valence measurments, the bumper valence on a 2006-2007 is 5.4" in height and the steel bumper is 9" in height. Could someone with a 2004-2005 measure their bumper and valence heights?
I also see a lot of people request BOTTOM OF MIRROR to GROUND measurments, so I took that as well... it's 57.4".
Originally Posted by FoMoCoFan17
Sweet. I was worried the coilovers didn't give that much more lift(didn't measure before the swap). I got 2.5"-3" on all those numbers. 37's here I come.
Oh also, BOTTOM OF REAR BUMPER to GROUND: 26.2"
Nevermind, I see you have the PC lift too and went with the PC coilovers. Where did you buy them from and if you don't mind me asking, how much did you give for them?
Also, I noticed in your gallery picture that your cam adjustments on the front crossmember are on the front of the truck. They're supposed to be on the back of the crossmember on the PC lift. Are you sure your front crossmember isn't in backwards?
Oh that's right, I forgot you were the one who won those. I didn't even have my ProComp lift yet and I almost bid on them. Awesome deal man... I'm jealous.
About the front crossmember, yeah I guess if it works then it's ok. Did you install the lift yourself? Did the lower control arms fit in ok?
How does the truck ride with the coilovers cranked that much?
Originally Posted by JonnyT
Baja did you just add that bull bar? You needed something like this...
sorry for the camera phone pics. but now all I need is that lift and tires....
And Baja, looks nice. When I first saw the thread title and your name, I thought it would be a prerunner truck
The truck rides great . Actually better IMO.
Ya think the backwards crossmember will prevent me from installing the skid plate in the futue? If tit does looks like the shop is going to have a little more work to do
I wanted to set the front b4 I set the rear.
