Back spacing
Old Jul 31, 2007 | 09:35 PM
extremeethan's Avatar
Back spacing
Which one is better for my truck, procomp 6 inch 35's for now 37's later.
6 on 135 / 6 on 5.5 Bolt Pattern; Back Spacing = 4.52 in.; Offset = -12 mm.; Hub Bore = 106.25; Finish = Black
or
6 on 135 / 6 on 5.5 Bolt Pattern; Back Spacing = 5.70 in.; Offset = 18 mm.; Hub Bore = 106.25; Finish = Black
Thanks in advance
Old Jul 31, 2007 | 09:38 PM
kalebarellano's Avatar
9in or 10in wide rims?
Old Jul 31, 2007 | 10:20 PM
mSaLL150's Avatar
with 5.70" backspacing your tires will probably be rubbing the upper arms=not good. the tires may also hit the frame at full flex. id go with the 4.52 backspacing.
Old Jul 31, 2007 | 10:36 PM
baja150's Avatar
Tuff4rd has 6" of backspacing on his wheels with 35x12.50 tires and has no rubbing.
ExtremeEthan,
IMO, the trucks with 4.5" of BS and 12.5"+ wide tires have too much tire sticking out of the wheel well. I think 5.5" is the perfect BS for 35x12.50's.
Old Jul 31, 2007 | 10:55 PM
ThumperMX113's Avatar
Originally Posted by baja150
ExtremeEthan,
. . for 9" wide wheels, yes. If you're going with 10" wide wheels, go with the 4.5" BS.
EDIT: What about your lift? Increase track width any? I thought my Rancho kit with the Helo Maxx 18x9 5.5" BS looked great.
Old Jul 31, 2007 | 11:03 PM
baja150's Avatar
Absolutely... should have clarified that. BS is all related to wheel width.
Old Jul 31, 2007 | 11:05 PM
baja150's Avatar
Sorry didn't see that edit. I'll take some measurments tomorrow, but I don't think the PC lift increases the track width at all if any.
And I thought your truck w/ the Rancho lift looked good as well. That was the gold truck correct?
Old Jul 31, 2007 | 11:07 PM
Yes.
Old Aug 1, 2007 | 10:42 AM
I looked and they are 9 inch wide, is there something better to 10 inch wide? Right now I am on 35x12.5 but around xmas I am going to 37x13.5 would a 10 inch wide wheel be better for those or does it not really matter?
Old Aug 1, 2007 | 10:50 AM
I'd try to stick with a 10" wide wheel but a 9" wide wheel would work. It'd wear a little faster and you'd need to watch your air pressure a little more to get the best wear possible but its doable.
Old Aug 1, 2007 | 11:04 AM
I work for a trucking company I watch my tires like no other, air pressure and rotations are regular. They only come in 18x9 so Ill just have to watch them, my wheels now are 18x9 and I had my 33x13.5 on them with no problems. I dont want any rubbing later so still go 5.5?
Old Aug 1, 2007 | 11:17 AM
I'd go for 5.5"
Old Aug 1, 2007 | 12:20 PM
Two things is not 5.5 its 5.7 will that make a big difference? and what is the off set on is like -12 and one is +18
Old Aug 1, 2007 | 04:09 PM
Edit
Old Aug 1, 2007 | 04:31 PM
my wheels now are 5.5 and my tires with the side lugs are close to the spindle with 5.7 it would be even closer right? Once I get 13.5 wide ill probable be right at the spindle then. Also I though my lift said 5.5 or less back spacing
