2 7/8" Drop Shackles and 17inch rims
Old Jul 1, 2007 | 11:28 PM
Racing2Fast's Avatar
Question 2 7/8" Drop Shackles and 17inch rims
Just a few questions I want to run by a few of you other members.
I have an 04 screw (2wd)
I just purchased 2 7/8" Drop Shackles. Will that lower the rear end of the truck and level her out? (I havent touched the front.. it's still stock height)
I also picked up a spare set of (4) 17" Factory Rim's off of ebay for a GREAT price. Im wanting to put some lower profile tires on the truck. Basically I want to get some Smaller Diameter Tires to play with out on the race track. That way Im not burning up the Firestone AT's I have on her now!!
Looking for some suggestions on a good tire size!!
Thanks!!
Old Jul 2, 2007 | 08:45 AM
04gtf150's Avatar
where did you get the drop shackles from, I have the Belltech 2" shackles, and I know that a longer shackle will not go under the truck
Old Jul 2, 2007 | 10:43 AM
You can check my gallery for "before and after" shots of my regular cab truck with 2" Ground Force shackles installed......
Old Jul 2, 2007 | 11:43 AM
ziggaboo's Avatar
make sure you get the pinion shims with that kit... 2 7/8 sounds like it may be tight up against the bed, and i know with the 2" kit you need shims. with almost an extra inch youre def. gonna need those shims so you dont shred your rear end/tranny/driveshaft.
Old Jul 2, 2007 | 04:53 PM
khendrix2374's Avatar
Try These Tires
They'd be the best for just rippin' up at the strip with the best results.
Old Jul 2, 2007 | 08:30 PM
sparkysvt's Avatar
i have kumho ecsta stx's on my truck. 265/60r17 99 ea from tirerack. i like em
