Mobile One Syn.
Mobile One Syn.
I bought Mobile One Syn. the other day. it is 5w-20. this isn't the 'extended milage' version or the clean 5000. Just straight mobile one. Anyone used this yet, and would it be reasonable to expect around a 5000 mile oil change intervals? Also using a motorcraft filter. This will be used in my 5.4l 4x4 w/ 12000 miles on it.
Sweet! Alot more than I expected. Hard to believe that somthing with the texture of water will give that much protection. Does our engine take 6 quarts of oil? i bought a 5 qt. jug and an x-tra quart for good measure. I'm sure this info is in the manual, just haven't looked yet.
They left out the part where they sprinkel pixie dust in the formula. lol
Originally Posted by From Mobile 1's website
FAQs for Oil Products
What is the difference between Mobil 1® Extended Performance and Mobil 1?
Mobil 1 Extended Performance formulas are designed specifically for today's longer service intervals and are guaranteed to protect for up to 15,000 miles or one year.
Mobil 1 Extended Performance has a unique formulation with a boosted level of protection and performance. Mobil 1 Extended Performance, with the Advanced SuperSyn System, contains 50 percent more SuperSyn than Mobil 1. (Updated March 2006)
Yeah that should be fine. Depending on how and where you drive plays a big part in how often you should change your oil.
Take a look at the oil as it's draining out. If it's dirtyier than you'd like than change it more regularly.
If you want to try and run it longer than 5,000 I recommend getting something to drain it into that has measurments on it so you can measure how much you drain out. All vehicles burn oil. Just make sure you're draining out at least 6+ quarts.
Also, the FL820S Motorcraft filter should be fine.
Here's a lot of good info on oil filters.
http://people.msoe.edu/~yoderw/oilfi...lterstudy.html
Mobile 1 is not what it used to be. It is a good oil, but tons of their loyal customers did an oil analysis of mobil 1 and they have noticed some change in the oil. Mobil 1 may have changed the formula to their oil, and some are saying it is not even a full synthetic. Mobil 1 extented performance remains the only synthetic in their line of products. I would stick with MC synth blend considering the price/value. Amsoil did an oil analysis for 5w30, Motorcraft synth blend did pretty well. Wmart sells MC 5w20 for a great price. in other words if you are not going to use the extended performance one, don't bother with Mobil 1 you are better off considering other synthetic Manufacturers.
You can check out the analysis, I am talking about at http://www.amsoil.com/storefront/asl.aspx and look for 100% Synthetic 5W-30 Motor Oil (ASL) to access the analysis.
A great resource for oil analysis and oil discussions is http://www.bobistheoilguy.com/ check it out
Originally Posted by Ilovemyford
Mobile 1 is not what it used to be......
want to know alot about oil? Got alot of spare time?
Edit: See this was posted above, but as mentioned great resource with a good forum
Originally Posted by luke280
I couldn't find Motorcraft at wal-mart. I'll never be able to tell the difference between one oil to another. So the oil that i have that says 'full syntheitic' and has met Fo Mo Co standards (says it on the container) is not compatable with my truck, or is that possibaly a little overkill? I'm sure that your statement holds truth, just wondering if this is starting to split hairs. Just want to know if it is safe to run on a stock engine. Thanks for the info though. I'll definately keep it in mind for the next time.
