Bushwacker guys
Old Jun 13, 2007 | 01:24 PM
Impact9's Avatar
Bushwacker guys
I just got my Pocket Flares in today and they are pretty cool and I plan to get them painted dark shadow gray. So my question is...
Did you use that edge trim seal that came with the flares?
If so, did you get that painted as well?
I see bushwacker doesn't recommend painting that but does suggest a flex additive if painted. Heck probably wouldn't even notice that black strip on dark shadow gray flares.
Old Jun 13, 2007 | 02:21 PM
KansasJoe's Avatar
The seal is so water doesn't get down there and so it doesn't scratch the paint. I would think if you painted them that it would be crisp and flaky which would nullify their purpose. The fronts are harder to put on than the rears and it helps to have a buddy push them up so you can get them on as tight as possible
Old Jun 13, 2007 | 03:26 PM
ferguson41's Avatar
Dont want to hijack your thread but I have a question on this subject and dont want to start another thread. I had mine painted and picked them up today. I am installing them right now, but I am concerned with the way that the front ones mount. Will the 3 plastic screw things really stand up to time?? I am thinking about bolting them onto their brackets and then trying to get the brackets to line up with the holes in the fender, I think that this will last longer this way....... What do you think?
Old Jun 13, 2007 | 03:54 PM
Impact9's Avatar
Now I'm wondering if I should even paint them. The black really goes with the overall black theme.
thoughts?
yes I plan on undercoating my wheel wells.
Ferg- I think they will be fine just look at all the others here running with them and no complaints that I've seen. You could always hit a hardware store and replace them with bolts and lock washers.
Old Jun 13, 2007 | 04:03 PM
ferguson41's Avatar
thoughts?
Def paint them. With your color it will really make it look great.....
Already did. I only have the driver side front to install in the morning. I had to take it back to have the paint touched up b/c I dropped the flare on the ground......
Old Jun 13, 2007 | 05:31 PM
Impact9's Avatar
Oh that sucks! I decided to go ahead and get them painted. There's a good paint shop 2 blocks away that's going to do them for me. I'll be dropping them off in the morning and they'll be ready by the end of the day.
Old Jun 13, 2007 | 06:03 PM
ferguson41's Avatar
Yeah, I was p!ssed. My paint shop did all 4 of mine for 150, I was really happy with their work tooo. If you dont mind me askin, How much are you paying for yours?
Old Jun 13, 2007 | 11:43 PM
Impact9's Avatar
$150 as well glad to hear that we're paying the same. i was thinking that might be too much when another user posted $70 unless that was a maaco job lol.
Old Jun 14, 2007 | 01:17 AM
baja150's Avatar
Spray some Armorall in there and it will look like new. I do it and get compliments all the time about how meticulous I am to even wash inside my wheel wells.
Old Jun 14, 2007 | 02:13 AM
Impact9's Avatar
i'll try that but i do need to undercoat in there with all the new lift parts installed.
Old Jun 14, 2007 | 05:37 PM
FX4_Off_Road's Avatar
I would recommend painting them but not the seal.. painted mine myself for $75 learning to paint is a good way to save $$. And it's so easy a caveman can do it!!
Old Jun 14, 2007 | 05:39 PM
freekyFX4's Avatar
I have a buddy that gave the inside of his pocket flares a few coats of that roll-on bedliner before he mounted them up. It made them much heavier and they seemed much more ridgid. Not sure if it really made any difference.
Old Jun 14, 2007 | 06:19 PM
Impact9's Avatar
That's a good ideal! I guess pep boys will have that stuff?
Old Jun 14, 2007 | 07:14 PM
freekyFX4's Avatar
I know WalMart has the Duplicolor brand...not really sure about the Herculiner or other DIY roll-on bedliner products. I used it to coat the inside of the rear fenders on my old F150 where rocks would hit the underside of the bed. I used the special loop roller to put it on and it made a really nice texture and looked great.
Old Jun 14, 2007 | 09:10 PM
Nytehawk's Avatar
Originally Posted by KansasJoe
The fronts are harder to put on than the rears and it helps to have a buddy push them up so you can get them on as tight as possible.
Odd, my rears where harder than my fronts. But I agree, it's better to have help to get them tight to the sides. I got my flares painted for 200 a few months ago. You guys are getting a good deal at 150.
