Truck stalling
My truck has started stalling. It appears to be when I let off the gas and hit the brakes to come to a stop or slow down for a turn. It just flat out dies. i did notice that my RPM's drop as if the AC was on(I think it has actually only happened when running the AC), it's almost as if it just doesn't idle fast enough to keep running. It always starts back up. Any thoughts???
TIA |
mines doing the same thing, now it just sits in my parking space. they told me one of the pistons had no compression. it runs like crap. cant wait to get my chevy.
Year, motor, milage, any aftermarket items? Your going to have to actually give us some info. Its like calling your Dr and saying "Im sick, whats wrong?". :rolleyes:
Originally Posted by jdeardor
My bad. 04 built in 03. 62K miles. Just had the engine broken down to the heads to replace the plus so I'm pretty sure it's not the pistons. It runs fine 99.9% of the time, it just started stalling out of the blue 2-3 weeks ago. No aftermarket items that affect performance, I had a K&N filter in it but recently went back to stock.
I had that problem, when i would come to a stop light the idle would go lower and lower until it would die. Ended up being a bad Throttle Body.
It actually started it the week before I took it in for plugs(did it 3x on me and threw the MAF code), then when the dealer was test driving after plug replacement it did it to them 3x(that's why the tested the battery), I replaced the battery and it has since done it on me 3 times. All within the past 3 weeks. I was curious if maybe the vapor management valve, throttle body??? Does anyone know the cost on those items, how hard are they to swap out(or can I even do it, does a reflash have to occur). Or any other ideas?
Mine does this exact thing when coming to a stop and it tells me right after it dies it reads "low oil pressure" as I have the Lariat with the electronic display. Another thing that happens is if I start it up and take off right away it goes into failsafe mode as well and gives me a DTC about the throttle actuator. Anybody have an idea what it could be?
my dad had a truck a few years ago, a 2000 f150, that did this. it ended up being an idle air control valve. I think it may be called an idle air control motor on the newer ones. just a thought.
Mine does the same thing (about 5 times a year) I just thought is the "super chip" but now you got me thinking.:mad: thanks
Same here with the stalling....
I cleaned my throttle body and move the TPS wire off the fuel rail. No problems sense. |
TIA |
Wow, a rash of the same thing! We need to get some of the senior members in here who should have some answers.
On 04's the stalling was a major issue when new. For most, mine included, a reflash cured the problem. It may be worthwhile with an 04 at least, to make sure it has been updated before swapping out parts.
