Broken!!!!!!!!!!!!!!!!!!!!
Old 06-12-2007, 02:07 PM
ok so i went out to the dunes this weekend ended up getting suck while in 2wd so i put it in 4x4 wont go in.... my buddy trys pulling me out with his super duty as he was pulling me out my 4x4 was still trying to engage..... as he is pulling me out my truck make some extremely loud popping noises like someone was hitting my truck with a sledge hammer so i end up stripping the gears in my transfer case!!!!!!!!! 2 hours later my friend who has a 06 f150 fx4 lift on a 6" procomp was driving around in 2wd decided he want to go into 4x4 "on flat ground" wont go in ends up do the same thing as me!!!!!!!!! anyone else have this problem?????
Old 06-12-2007, 02:10 PM
Electric Hubs = POS
replaced front left and right hubs on my truck last week
Old 06-12-2007, 02:11 PM
If the rear wheels are spinning at a different speed than the fronts, then you could have an issue?
Old 06-12-2007, 02:26 PM
4x4 wont even engage..... they arent pulling at all...
Old 06-12-2007, 02:29 PM
I think it says something in the manual about if the rear wheels are spinning do not engage 4x4.
Where ya'lls rear wheels spinning at the time? I can see people not thinking and spinning their rear tires at 3,000 rpm and trying to pop it into 4x4 at the same time.
Old 06-12-2007, 02:35 PM
Bud
Before your problems with it did it say that it was in 4WD on the dash light. I'm having problems with my 4WD but I think its from the accident, I'm not sure though. The dash lights up and I can feel it engage in the transfer case, the front driveshaft is spinning as well as the CV axles but I don't have any power going to them.
Anyone want to try to figure that one out. .
Old 06-12-2007, 02:44 PM
check yalls vaccum lines they had really ought to be extended when you lift your truck
Old 06-12-2007, 02:52 PM
Originally Posted by ThumperMX113
Bud
Ford uses a collar in the hubs on the newer models. It is vac operated and slides together some splines actually enguaging 4x4. By using a actuator at the t case and a hub locking system they are able to save slightly on rotating mass thereby reducing fuel consumption and vibration at highway speeds. Of course as your finding makes for a more complicated system and one that is more prone to failure. The rubber bladder that works with the vac line or the actual vacum hose its self is probably damaged now allowing the splines to enguage and by doing so keeping you from 4x4
Old 06-12-2007, 02:55 PM
I found these 4x systems done like to be enguaged with the truck is not rolling or if it is in a bind. I tried to put my 4x4 on then climb a nasty hill immediatly after. A loud pop was heard and it clipped out of 4x4. Backing up slightly and then popping it back in 4wd then rolling it a couple feel allowed the 4wd to firmly enguage and it didnt happen again. sucks because I like to play in 2w till I get stuck, but looks like when the going gets rough I have to put it in 4wd before the strain on the components comes into play
Old 06-12-2007, 02:56 PM
Exactly what I was thinking.
Old 06-12-2007, 03:01 PM
I'm hoping that everyone here is smarter than that. I think what he means is that hes putting it in 4WD but just the rear wheels are spinning, no front wheel movement.
Old 06-12-2007, 03:18 PM
Regardless...This 4X4 system is crap. Poping, cracking, in/out...way too much stuff to go bad. I am just waiting for this to happen when I need it most.
Old 06-12-2007, 03:50 PM
I have the same issue with my stock 05 fx4, and i'm taking it to ford this week while it's under warranty. will let yall know.
Old 06-12-2007, 06:14 PM
well thats just commom sense.... it was at idle.... i couldn't get it in so i put it in drive give a little gas wouldn't go in the put it in revers wouldn't go in any ways i made and appiontment for monday, i know its my transfer case im thinking i might just do gears right now as well...... what do you guys think 4.88's or 4.56's?????
Old 06-12-2007, 09:40 PM
lol So you are aying both f150s got messed up because they both tried to engage 4x4 in the same place on the same day? Now thats just funny
Quick Reply: Broken!!!!!!!!!!!!!!!!!!!!
Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
