FX2 Sport Forum???
#31
Originally Posted by Black 2000
So then the 5.4 2V with the eaton on the Lightning's and HD's make more power when that engine was rated at 260? How much boost do you think you would have to run to reach 350 on a stock block???
Black3v, think a one piece driveshaft would help out? Costly but we've spent money before.
Later...
Bruce
Later...
Bruce
aaaand you are in luck with the driveshaft since it already comes with a 1 piece 4in aluminum driveshaft. At least mine did (screw w/ 5.5 bed)
edit: as for never being able to touch Lightning performance...My brother has an '03 and we have raced to about 70 or so and he had me by about 3 truck lengths. From a 2nd gear roll it was much closer. His truck is basically stock except for an intake and tune and has gone 13.7 @ 100. We have yet to race since I did the exhaust and dynotune but I will bet its damn close. Same amount of boost except with mine weighing close to 1000lbs more.
#32
I'm sorry if you all are not as enthusiastic about this model as I am and I will happily drop the subject all together.
BTW stock what will a supercrew truck run in the 1/4?
Later...
Bruce
#33
well maybe our trucks are quicker than i think. all i know is that u see a roush 8 psi truck run a 14.9 according to that article which makes sense because ive heard that you add a 10th of a second on the ET for every 100 lbs. of extra weight... a full second off and ET is a pretty fair *** whupin in my book but then again i did a 60-100 with a lightning a while back before my tune and gears and it was pretty close... so who knows. its hard to compare unless you run them side to side a ful 1/4.
as far as a stock screw i would guess mid 16's on a good run.
#35
#36
http://www.edmunds.com/insideline/do...ticleId=116602
"14.9 seconds at 93.3 mph"
not saying that better times arent possible, but you will never see a lighting that will run a 14.9 unless there's something wrong with it...
#37
Just got done reading the article on installing an Edge Evolution Performance tuner on a 2005 Super Crew and Win Dyno'd at stock was 179.9 and 230.7 hp on the level 3 tune...Ford Performance Trucks Spring 2007 issue.
The Roush Stage 3 in question is in the same magazine and the best 1/4 time was 13.93 @ 96 mph. The Stage 3 is only a crew cab and rides on 20" rims. Article goes on to say this trucks weighs in at 5,520 lbs.
I'm gonna miss my HD. Nothing a couple of pieces here and there can't help fill that void.
Also what is the "recommended" tuner for these? The Evolution has some nice features just does not sound like you can go past or add custom tunes to it. Am I right on this or should I just stick with the X Cal 2???
Later...
Bruce
Later...
Bruce
#39
Originally Posted by ThumperMX113
I'd stick with the Xcal2 without a doubt, especially coming from your last truck. I have a feeling that this one won't be stock for long.
Later...
Bruce
#42
wow i cant believe they dynoed a 5.4 at a 180... thats horrible i thought these things put down at least 200-210...
Level 1: 179.9 hp @ 4,413 rpm/ tq 248.9 @ 3,607 rpm (transmissionn only)
Level 2: 211.0 hp @ 4,997 rpm/ tq 264.7 @ 3,633 rpm (towing)
Level 3: 230.7 hp @ 4,539 rpm/ tq 302.6 @ 3,563 rpm (High performance)
Again these were done on a SuperFlow WinDyn dyno, which I am not familiar with so I have no idea if there is a correction ratio for that type or not.
Seems like the perfect little tuner for the guys that just want a little extra seat of the pants go. MSRP on the kit is $ 489.00
Later...
Bruce
#43
#44
Those dyno numbers are way off to make the Edge look better than it really is and this is coming from a Edge owner. These trucks will dyno any where between 210-240 rwhp. I'd say its more around the 220-230 rwhp range for the most part but there have been a few abnormalities just like in anything.
#45
Whatever, just curious to see what some have seen on the rollers.
Later...
Bruce
