Axle Wrap
Originally Posted by rtremaine
I am not aware of any traction bars specifically for the newer f-150, however I would imagine that the universal competition engineering brand bars might fit. where exactly are your driveshafts failing? Is it the driveshaft tube itself or the rear u-joint?
If you have enough people that want traction bars ... these guy's will make them they are the chit
http://www.calvertracing.com/
Originally Posted by styxnpicks
the new f150 don't like flip kits for some reason
I think i'm done with with the whole droping the vechile, it looks just fine with just the 2" shackle. Unless I do the Air ride tech.. anyone know how the front shockwave air shocks are?
Originally Posted by 05_F150
I noticed, I had the Mcgauhty 2/4 with the 4" rear leaf and thats when I snaped my axle (had to be to soft of a spring, cause it axle wraped bad with that setup) then I went back to the 2" rear drop then to the 4" rear flip, now back to the 2" drop. Did all work myself could be a reason my truck doesnt drive new . I dont think my KYB shocks help at all, those are a really hard shock, anyone think I should go back to stock shocks?
If you have a flip kit.. you'll have to make you own or modify some existing brands.
If you have different springs... or just have lowering shackles.. these will work for you.
http://www.stylinconcepts.com/parts..../categoryid/30
Look up Matt 05'FX4. He has some of these bars. They will eliminate any axle wrap. I'm making my own right now.
Originally Posted by Impact9
Now that I'd like to see!
BTW pro comp makes traction bars. Does your truck sit too low to use those?
you need something like these under-ride bars. The bolt to the bottom of your leaf springs using the axle u-bolts and then run up and mount of the frame somewhere. any 1/2 way decent metal shop can build you something like this for under $200
btw, this is only good for 4x2 trucks. for use on a 4x4, you'll need a good heim joint on either end of the bar to allow for the axle articulation while off-roading
I found that bar here
Under-Ride Bars
you might be able to make 'em work on your truck, but it ain't likely
