Avic-D3 On the Way!!!
#46
I am ordering this unit too but i went down to my local shop and they said that factory sub isnt reccomended with an aftermarket deck cuz it can either blow the sub and wreck it. They said they can do it but its just put togeather not in a legit way and if something happens than its my responsbility. Are other people running the factory subs?
#47
Originally Posted by murray330
do you have to hook up a microphone and connect it to the hu, or can you use a bluetooth headset? i guess i'm not really sure how you talk once the hu picks up the phone.
#48
Just made the purchase last night on my new d3!! excited as hell, and could hardly sleep! also picked up the bluetooth adapter, ipod adapter, and review camera.
purchased everything from crutchfiled. It was a little higher priced then most websites, but i needed a little piece of mind. Some of those websites that had mentioned earlier, i did a "website site" review on. I saw several people have problems with late shipping, customer service issues, and just basically bad taste. Also, with crutchfield, I added the 15% discount coupon whiched saved a bundle! (3 pioneer purchases needed, and the coupon is good until the end of this month 3A185 i think)
thanks for all the ideas posted!!! This site is so great, but it's like a double edge sword. On one side, it's great because you can get a lot of answers, but on the other there are so many ideas a guy could go broke!!
#49
#51
Originally Posted by SAtownTX
so can i get some conformation on the factory sub with this?
#53
Hey Guys,
Just installed the ipod wire and also the XM radio kit. I was able to use the factory sirius antenna by taking off the plastic clip. Just activated, so i havent actually listened to or checked out the features. Next up will be an ipod to complete the system.
One other note, I tried to install some custom backgrounds using directions from avic411.com and cant get it to recognize the pics. followed instructions, im gonna try again with another disc.
greg
greg
#54
Avic-D3
Hi! New here, just got my 05 FX4 flareside last week. The factory radio cd player was jammed when I got it so I knew I was going to replace it anyhow. I just ordered the whole thing from Crutchfield. First the people who they get the harnesses from packed the wrong one in the right bag. I called Crutchfield and they overnighted a new one free. I just hooked it up about an hour ago. I didn't bypass the brake yet (I did it to the books). It did help about you guys saying about the pink wire. THANKS!! As for the factory sub I did get a harness with the main and hooked it up but I don't think it's working.? How do y'all have the antenna going? I'm going to go up in the headliner and out the bottom of the third brake light like my portable XM. Also, do I HAVE to hook up the reverse wire? If so where do I tap in that? Thanks for everything so far fellas! I may have more questions later.
#55
#56
Originally Posted by gregbj33
Hey guys, Installed it this morning, and you're all right pretty easy install. the grey and black wire for speed sensor was easy and the black and pink reverse wire took maybe 3 mins to locate and connect. I'm assuming that under the staus screen where it shows, gps strength, illumination, park brake, etc. it said parking brake on and it wasnt that the bypass mod was a success, is this correct. also what is the back up line that shows low. any other quick tips now that everything is a go. for those with audiophile, does anyone have some eq and sub setting that maximize the potential of this system.
once again thanks!!!!!!!
#57
have a question. i have the ipod adapter (cd-i100ii), bluetooth adapter (cd-btb200), and the d3. the back of the d3 has an ipod connection that is grey and female. The cable with the cd-i100ii is female and either grey or black. (meaning, i can't connect it to the d3. The question is, can i (or has anyone done this before) connect the cd-i100ii through the cd-btb200 and then go into the d3 still getting the full use of the ipod through the d3?
i contacted crutchfield (whom i bought the stuff from) and they said they are unsure of whether this will work or not.
just trying to save the hassel of returning it, but also want to save a step in connecting it if it's not going to work.
thanks for the help!! and i can't wait to start playing with it!!!!
#58
the ipod cable you have is not the correct cable...the cable that you need is the Pioneer iPod Direct Cable (CDI200). you should just run to bestbuy or circuit city and pick it up, then return the cable you have.
http://www.crutchfield.com/S-0BQJXk1...50&I=130CDI200 this is what you need.
i have no clue if that combo would work, you would probally need to talk to pioneer.
#59
Originally Posted by thenewbreed
The link shows a red f150. But when I click on your camera icon its a white f150. Whos is that it looks great.
thanks!!!!!
