Starter Wire
Old May 14, 2007 | 10:22 PM
Josiah's Avatar
Starter Wire
I need to find the starter wire, anyone know which color wire it may be or have a tip on how to find it other than starting the truck while using a test light (which I am about to try).
Old May 14, 2007 | 10:42 PM
BestNTx's Avatar
I read that you are doing the push button ignition starter I know that etrevino did that mod, if you can get ahold of him maybe he can give you some pointers.
Old May 15, 2007 | 12:15 AM
Josiah's Avatar
I found it. Mod will be done tonight, expect nighttime pics. I got the lighted Ignited Ignition. Like this but red. I re drilled a hole for the cig lighter. Thanks BestNTx. And I looked in etrivino's posts and he never ended up doing it.
Old May 15, 2007 | 01:08 AM
BestNTx's Avatar
How does it work and what are some advantages of the push button start?
Old May 15, 2007 | 01:17 AM
Tuff4rd's Avatar
Snap some pix when your done
Old May 15, 2007 | 01:34 AM
06 SRT 10 X2's Avatar
Not sure of any advantage but it sure is fun
Old May 15, 2007 | 02:16 AM
etrevino103186's Avatar
I did!
Old May 15, 2007 | 02:41 AM
Josiah's Avatar
Originally Posted by etrevino103186
I did!
Any pics? Where did you tap into power, did you get the lightup version, and what wire did you tap into for the starter?
Old May 15, 2007 | 02:54 AM
zachespo's Avatar
Hey Joshia do you need a wire that turns on when the key is turned to the on possition? If so I found one in the steering column that I used for my second battery solenoid. Let me know and I can see what color it is.
Old May 15, 2007 | 08:06 AM
OnBelay's Avatar
Do not use just ANY switched wire for powering the push button. Take a look at the size of the power wire for your ignition switch (light green/violet and red/light blue). There is a reason those wires are so much bigger-because of the amount of current they carry.
I'd bet the reason you are blowing your radio power is because you're drawing waaaaaaaaaay too much power through the circuit.
Old May 15, 2007 | 01:04 PM
I'll have to check on those wire colors for you. I want to say that I tapped the power wire for the headlights or the radio. I had to tap the starter wire and run the ignition through the switch. It is kind of mess down there bc I have this switch that cuts of the starter off.
Old May 15, 2007 | 03:46 PM
ford2004F150's Avatar
FYI....
RED w/ Light Blue starter wire is located in the ingnition switch harness.
