35s 2.5" level, and aftermarket wheels.
I have only seen 1 truck on this site that had 35s 2.5" level, and aftermarket wheels. It looked like he had to do a bunch of trimming. Whatever you do though make sure you check the backspacing on your wheels.
2004 F-150 Supercrew 4X4
2" AS spacers in front/ stock (trailer towing pkg) rear height
17X9 Mickey Thompson Classic2 wheels
315/70/17 (34.84" tall inflated height measured on truck)
Absolutely no rubbing, no time, no how, even lock to lock on the steering...
Well, I hated to see my 315 BFG's sitting in my shed not mounted on wheels, so I'm going to try them on again. Ordered some American Racing Crush wheels and hope to get the tires on tommorrow. Ought to give a little more clearance than the wheels I have on now. I'll just have to keep from going offroad.
35x13.5x18or 325/65/18
I have a bunch of pics in my gallery of my modifications. shave inner fender,front valance, installed a bolt through inner fender and frame body support to hold the fender back and no I would not recommend off road with 35s Tires would rub inner fender Here a picture of my modification that i stuck a bolt in my inner fender and drilled a hole in my frame body support I inserted that bolt more pictures in my gallery
shaving rear inner fender
I sent Wandell a PM earlier this evening but he's yet to reply. Seeing as this thread touches on my concerns, I'll ask here and hope someone can chime in with some insight.
My truck's a 2005 Lariat 4X4 Screw. My truck will have a 2.5" levelling kit installed on Friday. There's no other lift. I was originally going to stay with OEM 18" wheels and throw some 35's on them but I figured "hey, you only live once so go the whole shabang."
I'm going with the Moto Metal 951 20X10's wrapped with Toyo Open Country MT's 35x12.50R20's.
I don't understand anything about "backspacing" or "offset." It's just not my strong area . . . but I know these two words are important in the selection of aftermarket wheel/tire combos because I've been reading about them more n' more of late.
My question is this: I want my wheels/tires to stick out no greater than 1" more than what the OEM wheel/tire combo did [2" at absolute best]. Do I need to tell my guy anything about "backspacing" or "offset" before he orders the parts and performs the install or am I worrying over nothing? Will this combo fit fine or should I alter something?
I don't care about any shaving of the fender wall or guard lip. I just don't want any "bulge" when viewed from from the side and no rubbing whatsoever. I know this wheel/tire combo is what I'm after in terms of appearence after researching for many months on these boards, but after reading several threads/posts of late, I'm begining to think maybe this in' gonna work...
Any assistance would be greatly appreciated.
Am I better off with the 33" Toyo Open Country MT's?
The 35" MT's are listed at 13" overall width as opposed to the 33" which are listed at 12.6" [LINK]
That's about one-half inch difference, which isn't a lot.
Any idea how much more pertrusion than the OEM tires I can expect with either size Toyos?
I would like to "fill" in the wheel-to-fender gap and that's why I opted for the 35's.
Guys 35's are going to rub even with a 2.5" leveling kit. Your 315's are slightly smaller and that .5 inch is just enough to make a difference.
Jump in the aftermarket tire and wheels forum here and search the post there. From what I recall 35's will not fit on a 2x4 even with a 2.5" kit because the suspension is smaller.
Originally Posted by Jwool15
i wonder if 35's are possible on a 2wd with a spacer and oems.. Anyone on here tried that?
