Accident damage
Old May 2, 2007 | 12:49 PM
ckforker's Avatar
Accident damage
I got hit again... yesterday. I don't know who I pissed off, but I have had the truck less than 2 years. Anyway, I was hit in the drivers front wheel and door. I want to know what I should look for as far as possible damage to the suspension. The truck is drivable, the wheel is bent and the steering wheel is only slightly off center. The adjuster is coming by tomorrow, and I would hate to get it fixed only to have possible bearing damage or something else that they might not check. Any insight would be appreciated.
Old May 2, 2007 | 01:00 PM
SR89racer's Avatar
i was hit in probably the same spot except on teh passenger side. A guy ran a stop sign doing 60 and decided to hit his brakes after the stop sign! my rack n pinion was cracked in half and i wasnt able to drive it! It cost 13,000.00 to fix it. i only had the truck 8 months!
Old May 2, 2007 | 01:06 PM
SR89racer's Avatar
have them check to see if the cab of the truck moved off the rubber mounts where the bolts go! also check the teh supports under the floor and make sure oyur dash didnt move! my glove box wouldn't shut after i was hit!
