Torque specs
Old May 1, 2007 | 04:48 PM
jec1521's Avatar
Torque specs
Anyone know what the torque specs are for rear shackles and U-bolts?
Old May 1, 2007 | 05:08 PM
bamorris2's Avatar
According to the workshop manual...
To install, tighten the U-bolt nuts in 4 stages.
Stage 1: Tighten in a cross pattern to 35 Nm (26 lb-ft).
Stage 2: Tighten in a cross pattern to 70 Nm (52 lb-ft).
Stage 3: Tighten in a cross pattern to 100 Nm (74 lb-ft).
Stage 4: Tighten in a cross pattern to 133 Nm (98 lb-ft).
Torque Specifications
Description..........................Nm.....lb-ft
Shock absorber nuts..............90........66
Spring-to-frame nut..............300......222
Shackle-to-spring nut...........133.......98
Spring shackle-to-frame nut...133.......98
Old May 1, 2007 | 05:11 PM
jec1521's Avatar
Thanks a lot man.
