Belltech Rear Swaybar
Anyone running the Belltech rear sway bar, #5548? In another post, I posted that you can't run the Hellwig bar with the Maggie 16612 cat back. Tail pipe and bar are located in the same space under the truck. So that bar is out and I wonder if this one will work. Anyone got one?
I took out the Helwig to install the cat back. After that I ordered a Belltech rear antisway for replace the one I took off.
The belltech will clear the mangaflow rear exit system, it mounts similar to the 99-03 Helwig did.
Seems to work the same, but I am comparing with 275/65R18s on my '06 vs. 285/60r18s on my '01. Bit of a tire difference, so it is not going to be a true apples to apples comparison.
That's great to know. Thanks very much for the reply. Where'd you buy it?
I'm sure the belltech will provide better control, like the Hellwig did, vs having no bar at all.... Why doesn't Ford put one in these like they do with the camper package on a SD truck....
Thanks!!
Thanks!!
