Transmission trouble?
Old 04-06-2007, 08:21 AM
theanimal's Avatar
Ok heres the deal.
When I take off from a stop, if I hold the rpm's at a steady 1100 or so, the transmission will shift through all the gears.
I am literally doing 5 mph in overdrive. Then if I give it more gas it downshifts and takes off and shifts fine.
Does anyone know what might be causing this? Maybe the speed sensor?
Old 04-06-2007, 08:31 AM
TexfordD's Avatar
That's what they do
Old 04-06-2007, 10:50 AM
theanimal's Avatar
No, it shifts through all the gears in about 3 seconds.
It never did this before but its all jerky and just not right
Old 04-06-2007, 06:59 PM
Silver04f150's Avatar
I'd unplugg the battery for like 30 minutes. it will reset the computer
Old 04-06-2007, 09:05 PM
quackrstackr's Avatar
Mine would do that when slowly headed uphill and completely load the motor in OD. Sounded like it was going to throw a rod the two times that it happened.
They reflashed mine and it hasn't happened since, although I haven't attempted to recreate the two situations where it happened either.
Quick Reply: Transmission trouble?
