Tire Pressure Sensor
Old Mar 18, 2007 | 05:40 PM
Cadmaster's Avatar
I have a 2005 F-150 with the 5.4 motor and 4 wheel drive. Does my ruck have wheel pressure sensors? I can't find anything in my owners manual, but my manual came out of another truck because mine was missing it when I bought it.
Old Mar 18, 2007 | 05:54 PM
txnole's Avatar
Do you have the original sticker? That would be the easiest way to check. Your dealer can run your VIN for a factory list.
As best I can recall, tire pressure monitors came up on the option list for 2007 models, but it may have been available on some 2006s, too.
Old Mar 18, 2007 | 05:56 PM
cndcowboy's Avatar
No.
Old Mar 18, 2007 | 07:10 PM
chris1450's Avatar
tire pressure monitor is new for 07... and it is standard. Any one have a 07 and put new wheels on yet? I wonder if there is a way around the light going on if the wheels don't have the sensors.....
Old Mar 18, 2007 | 07:16 PM
mr_andy's Avatar
......could it not be strapped onto inside of a different rim? One of my pirellis went flat and the senor is a black box strapped to inside of rim......wireless transmtter maybe?
Old Mar 18, 2007 | 07:42 PM
Matt 05'FX4's Avatar
2005's aint got em and the transmitter should be able to be transfered to another wheel. I'm not sure what the Ford ones look like but I know the ones at work are made onto the valve stem and can be removed and exchaged. And yeah, there are small antennas at each wheel that pick up the signal from the TPS. I think at first they came out with regulations to only have to detect like a 25% loss from one tire to the others so lots of manufacturers used wheel speed difference to detect a low PSI on one corner.......but if all 4 tires were equally loosing pressure then that system would not work so they changed it and require the systems to detect actual PSI using the sensor in the wheel.
Old Mar 18, 2007 | 08:29 PM
mr_andy's Avatar
....it's a small flat black box that's on a strap that's strapped to the inner circumference of rim, it's not near or associated with valve stem from what i could tell. The tire guy was glad i warned him about it.
Old Mar 18, 2007 | 09:20 PM
Red03SVT's Avatar
I just bout a '07 s'crew Lariat yesterday and last night at about 90 miles on the clock the sensor light went on
guess I'll have to take it back to the dealer amd see what's up.
...but the truck's great otherwise!!
Old Mar 18, 2007 | 11:54 PM
Quintin's Avatar
Try checking and adjusting your tire pressure first before wasting the dealer's time. Get a digital tire pressure gauge, and set them cold. 2-3 psi low can turn the light on.
