*** Soft Brake Pedal Resolved ***
#363
The reason I came upon this thread-Sunday night I was driving in sandals that have a bigger sole than my normal shoes. I was driving on auto-pilot coming to a stop and WTF?, I surge forward, I have to slam on the brakes. Turns out I hit both go and stop at the same time!!! My wife looked at me with that glare that says " YOU, you claim to be the safest driver on the planet, no ticket nor accident in decades and you almost rear end the Dover White Camry ahead of us in broad daylight in no traffic on dry pavement?" The words she said were "I guess the seat belts work." Point is this is a SAFETY ISSUE, after the adjustment I have .75" between the lowest brake point and the highest acceleration point. I backed t up one turn (360 degrees), it took 15 mins.
Tip-borrow a little nail polish from wifey, draw a line from the bolt you have to hold with the needle nose pliers (it's the one harder to get at, not the 7mm end cap) to the end cap piece that is 7mm. This will give you a point of referance.
#366
I'm SO glad I found this thread! I've had this problem with my 2000 F-150 (V6) for years. About three years ago, when having the brakes done, a mechanic suggested putting a new master cylinder in, but it didn't really solve it. So I've been basically living with it, and even recently several different mechanics have said (guessed) that it needs another master cylinder, a complete power flush, maybe new calipers, or adjusting the back brakes (which were already adjusted as close as they should be).
Then yesterday after reading this thread I took the master off, then using a stiff wire with white insulation that I could mark on, measured how far in the piston was, then subtracting the portion of the master body that goes in the booster, determined that the tip of the actuator rod was around 3/16" away from the piston when installed! I went ahead and backed out the rod about 2 full turns (about two more threads exposed) and put it back together to test.
For the first time in YEARS I had a good solid brake pedal! The drop had been almost halfway before, and that was with new front pads and new rear shoes. But it was a bit too stiff, so I took the master back off and turned the rod back in about 1/2 turn, and it feels like a brand new truck now. I went to an incline and put it in neutral and it rolls back fine, so think it's about right (brakes not rubbing).
In fact I almost rear-ended someone recently because of the pedal drop and poor braking, so finding this solution was a God send.
So a big THANKS to to OP, and to the mods for making this a sticky. Wish I'd seen it years ago
BTW, here's a pic of the rod for folks coming to this thread late (like me).
As-said, just use needle nose to hold the splined part, then a small wrench or small channel locks to back out the black tip.
The following users liked this post:
#367
great tip. turned the rod one full turn out. took it for a ride and was most impressed. came back and jacked the front and the wheel was dragging. turned it in a 1/4 turn and took it for a ride. still dragging some when jacked. turned it in another 1/4 so at this point it was a 1/2 turn out. brakes did not grab like the first test drive but much better than they had been. brought it back and jacked it and the wheel spun easily. may tweak it in the future but i think the 1/2 turn out that it is now is good.
thanks again for sharing the tip.
#368
#369
#370
#371
I gave the actuator rod a full turn on my 2003. BIG difference. The pedal is still a bit spongy for my liking but its firmed up a great deal. Before, it was like stepping on a loaf of fresh bread.
I plan to drive it for a week or two and see how it goes. Maybe another 1/4 turn to really firm up the pedal.
Many thanks to the OP and all the other contributors!
#372
Add me to the full-turn club. Much-improved feel, and no drag. To verify, I coasted to a stop on a slight incline, and felt no drag/hesitation when coming to a stop nor when starting to go backwards, then drove a bit on the highway, (cautiously) felt each rotor, and all were cool.
It may actually stand another 1/4 turn or so, but I'll leave it where it is for now.
As an aside, even with the new adjustment, I STILL can't lock up the tires, even when standing on the pedal, and even when on a damp road surface. I do have 265 Goodyear Wrangler Silent Armors on there, which have great grip, but still... Makes me wish I'd upgraded the front lines to braided S/S, maybe?
Andy
('99 4x4 Lariat Ext Cab)
Andy
#373
#374
Andy
Andy
#375
And my Abs is deactivated, but regardless, no, I cannot lock the wheels up.
Andy
