Tell me if this can be done
Old Feb 27, 2007 | 12:09 PM
Brandon Miller's Avatar
On my 2004 Lariat Supercrew 2wd I am about to install the spacer up front and the 4x4 blocks in the rear. With this setup, can I clear Moto Metal 951s 20x10 with a 305/55-20 (33 x 12.50) tire? What offset/backspacing is required?
Old Feb 27, 2007 | 12:20 PM
ford2004F150's Avatar
What size spacer? What kind of spacer? Come on now...
Old Feb 27, 2007 | 12:33 PM
Oops sorry. Either the 2" or 2.5"
Old Feb 27, 2007 | 01:18 PM
Go with the 2.5
Old Feb 27, 2007 | 01:21 PM
What brand would you suggest?
Old Feb 27, 2007 | 01:50 PM
mmotes's Avatar
autospring all the way...put mine in a while back and haven't looked back...love it!..._motes
PS- and yes the 33's will fit with stock rims...i'm not sure what backspacing you need cause i've got 34's on my stockers...._motes
Old Feb 27, 2007 | 02:11 PM
I am planning on getting the Moto Metal 961s in a 20x10.
Old Feb 27, 2007 | 04:52 PM
quickie4x4's Avatar
Mine is an FX4 and the 33x13.50 on 20x10 Moto Metal 951's rubbed a bit when I only had the 2.5 spacer in. I would venture to guess that you wouldn't be able to turn at all with the 2.5 spacer and that tire/wheel combo on a 2wd. You could fit 33's on the stock wheels or a wheel with similar backspacing and most likely be fine with just the spacer though.
