intake guys, here!!!
Old Feb 25, 2007 | 04:58 PM
Hostile03SVT's Avatar
hey guys, i installed my new intake yesterday, and late lastnight my check engine light came on.. today i disconnect the negative terminal off the battery let it sit for 15 minutes then re-connected it.. truck stumbled a bit until the MAF sensor calibrated.. i take it for a ride on the highway to home depot and it was fine, on the way home it came on.. this intake is the EBAY special lol i know i know laugh.. it is the identical intake aside from the filter to the MAC intake setup.. is there anything that i can do to get rid of the engine light?? has anyone experienced this problem with there intakes?? all info appreciated
Old Feb 25, 2007 | 05:01 PM
SuperSport1985's Avatar
Give it the once over and make sure you didnt forget to hook up a sensor also check your clamps if any around the mass airflow sensor happend to me it was sucking in air after the mass airflow also known as un-metered air lol.
Old Feb 25, 2007 | 05:11 PM
thanks bud i gave it the 5 over.. lol... im wondering if most intakes need a programmer to correct the metered air flow??
Old Feb 25, 2007 | 05:25 PM
FX4 Matt's Avatar
Registered User
Take it off and put it in the trash, you might be running lean and could be running the risk of Fing your truck up.
Old Feb 25, 2007 | 07:12 PM
chief40al's Avatar
Rich
You can read the code with your L tuner
and look it up, this might help.
Old Feb 25, 2007 | 07:42 PM
Dribone's Avatar
its def. running lean. our trucks are running lean from the get go, you're just forcing that much more air through there. not sure why other companies don't trigger the sensor though. trash it and spend some money on a good one.
i hate to say it, and i'm guilty of it too, but "you get what you pay for"
Old Feb 25, 2007 | 08:20 PM
thanks guys im going to see if the A-hole will take it back and refund me my money..
Old Feb 26, 2007 | 02:04 AM
ok guys, how about if i put lets say an EDGE on it?? would the programmer correct this problem???
Old Feb 26, 2007 | 02:31 AM
sandyf150's Avatar
the edge only lets you add more fuel at WOT. you could get rid of the CEL but that would be a bad idea since you would still be running lean... I guess you could get a custom tuned XCAL2
Old Feb 26, 2007 | 02:45 AM
BAKORACER's Avatar
If you get the edge you will at least be able to read the code and if you end up taking the intake out you will still have the tuner for extra hp. If you haven't yet take the entire set up out and reinstall it. if the directions arent clear d-load some from K&N or another manufacturer, the basics are all the same. After you do that recheck EVERYTHING when I installed my K&N I forgot to check one of the sensors and it flipped a cel. Last, unplug your battery for a longer time, 15 mins isn't always enough to drain what power is left in the system. leave it for 30-40min. If all that doesn't work...it is better to trash a bad $150 part then a good truck.
Old Feb 26, 2007 | 08:52 AM
Copperhead64's Avatar
I couldn't have said i any better especially the last line.
Old Feb 26, 2007 | 05:34 PM
thanks guys for now i took the intake off.. im waiting for a call back from a tuner with a used SCT unit, i might just have it tuned and try to squeeze some ponies outta her...
