Is the Edge worth it?
Old Feb 22, 2007 | 09:56 AM
jdew1920's Avatar
I'm not a performance freak but I'm thinking about getting the Edge. I have an '06 SCREW with the 5.4 I tow a trailer that approaches 7000lbs when loaded. I was thinking of adding a trans temp gauge and possibly one other but I'm thinking I'd probably be spending nearly $200 on that so I might as well spend another $100 or so and get the Edge and have access to many other paramaters. Not to mention I do think the shift points could be tweaked a bit on this truck - needed whether towing or not.
What do you guys think?
How does using the something like the Edge affect your warranty?
Old Feb 22, 2007 | 10:05 AM
05supercrew's Avatar
Definitly well worth it, you wont be sorry.
Old Feb 22, 2007 | 10:09 AM
I have the Edge and really enjoy all the gauge info. If i were doing heavy towing, would definitly want a tuner, either the Edge or Troyer's Xcal2 (but it does not have gauges). Yes, many dealers would try to say the Edge caused your problem if it could possibly be related. That is one of the reasons some go back to stock and remove it when going to the dealer. My dealer is one of those, so i waited until my warranty was almost out before getting the Edge. I have about 12,000 miles on it since adding the tuner with no problems.
Old Feb 22, 2007 | 10:33 AM
beckerjs's Avatar
Old Feb 22, 2007 | 10:51 AM
supachargd2k5's Avatar
I have the edge and love it. Just return to stock mode and remove it when going to your dealer and you'll be fine
Old Feb 22, 2007 | 12:15 PM
goslow's Avatar
I also just got a trailer and wanted to put in a transmission temp gauge and decided to just get the edge.
It's nice, you can set an alarm for some of the things it monitors at a set point you decide in addition to showing them on the gauge if you want.
So say you want to know when the trans fluid is at 200 you can set that and it will alarm if it gets to that temp.
The change on the transmission shift points is also nice in level 2.
Old Feb 22, 2007 | 12:25 PM
I like my edge evo. Everything I wanted in a tuner so far.
Old Feb 22, 2007 | 12:41 PM
glad to hear you say that. glad you worked through your problems.
Old Feb 22, 2007 | 12:43 PM
SHHHHH about edge and problems.
Old Feb 22, 2007 | 01:01 PM
hmfic's Avatar
Have it, would not own another F150 without it. It has more capability than I'll ever need.
Old Feb 22, 2007 | 03:46 PM
Copenhagen848's Avatar
It's well worth it IMO....it adds a nice amount of performance increase, but most of all, I like the way it looks and the various guages.
Old Feb 22, 2007 | 03:57 PM
06FX4's Avatar
I have it and will never get rid of it
Old Feb 22, 2007 | 04:18 PM
milo99's Avatar
I was really surprised with mine. I like it a lot. Im running the settings that "bluejay" posted a while back. I havent tried anything else. I would say it was definatley worth it.
Old Feb 22, 2007 | 04:21 PM
-TXF150-'s Avatar
I would wait for the livewire..
Old Feb 22, 2007 | 04:53 PM
zachespo's Avatar
Hopefully it will be out soon so I can upgrade.
And i think the EDGE is totally worth it.
