Code P0607?????
Old Feb 18, 2007 | 12:13 PM
06FX4's Avatar
Exclamation Code P0607?????
Ok so this morning i go out to start my truck and the battery is completly dead! im not sure why, i did leave my radar decter on and i havnt driven it for like over a day now and its really cold plus as most of you know these battery's are crap anyway, so i went ahead and hotshoted it with my moms mountineer and it fired right up but then the little engine light came on and i pulled the code with my edge and got P0607 unknown, i searched but i couldnt find a clear explanation of what it is, should i go to the dealer or somthing, i cleared the code and so far it hasnt come back. what should i do, thank!!!!
Old Feb 18, 2007 | 12:26 PM
Racing2Fast's Avatar
I couldnt find any info on P0607 either.... You sure that's the right code? I pulled a P0507 the other day.
I'd just get a new bat, and reset the ecm and drive it a while and see if trips the code again.
I reset the ECM cleaned my MAF and Throtle Body, re-cleaned the K&N and she's been good to go since then.
Old Feb 18, 2007 | 12:48 PM
06FX4's Avatar
i just went and drove it around for like 45min. and the code hasnt come back and its not acting wierd or anything so i guess its ok, i just want to know what it means lol
Old Feb 18, 2007 | 01:41 PM
06FX4's Avatar
Old Feb 18, 2007 | 01:46 PM
FX4_Off_Road's Avatar
My book says the P0607 is 'Control Module Performance'. Have no idea what it means tho...
Old Feb 18, 2007 | 01:55 PM
lastorms's Avatar
Since your battery died, your pcm prolly had to relearn your edge
P0607 Control Module Performance, indicates PCM's CPU encountered an errror. Possible causes- module programing error, aftermarket performance products (ie edge), or damaged PCM. I wouldn't worry to much unless things start running funny
Old Feb 18, 2007 | 02:27 PM
06FX4's Avatar
thanks for the help!! ya i had a code pop up last summer when my OD kept turning back on after i would turn it off and when i took it to the dealer they told me it was the performance module or somthing like that, they reflashed it and it went away, but it is acting fine so i goin to asume it was cause the bettery died. Thanks for the help!
Old Feb 18, 2007 | 02:37 PM
lastorms's Avatar
Glad i could help
