Antifreeze smell and truck instantly fogs up
Originally Posted by beckerjs
get off your ars, turn the a/c on for 5min, if water is dripping from right side you are good, if not then find the drain and poke or blow it open. Dealer aint touching my truck for that little thing.
So. . . since the general consensus is that this is going to cost me big bucks and I am 2 years into a 3 year lease, should I try some of that Prestone Stop-Leak stuff and see if that helps? Or am I just wasting my time?
Thanks for the advice so far.
anyways if you take your time even at a friends house in a garage, there is no reason you couldnt get it done in a day.
stick with your motorcraft premium coolant that the truck came with
I don't have access to a garage, none of my friends have one either. Or if they do they have projects on the go that can't be moved.
Could you please elaborate? No to they don't work or No as in they are a bad idea and will cause further harm?
bottom line, there is no such thing as a mechanic in a can.....
stick to your normal fluid for anything, and dont use any additives.
That sucks that heater core is a pain and as far as the stop leak that is a hit or miss deal and yes it could be twice as harmfull than doing you any good. I work at a shop and we could probably do it for around 800.00 give or take seems like there isn't an aftermarket heater core available.
