diff fluid too thick???
installing chrome diff cover and purpule cranium rock crusher cover. owners manual says 75w90 but i bought 75w140 royal purple. will that be too thick, also do i still need to add an additive, its says it is already in the fluid. i have not drained it yet so i can return it. thanx for the help
only put the recomended weight in. That tick oil won't get into all the small areas it needs to as easily and you can burn up your rear end. Someone said that they put the friction modifier in even though royal purple has it. Is yours a limited slip axle? If not you don't need the friction modifier
Originally Posted by Quintin
75W90 is being phased out for use in most axles and is being replaced with 75W140. You'll be fine.
I had just change it and put in Mobil 1 75W90. He said I would be fine until the next change.
on
Originally Posted by ThumperMX113
Just curious, why is the 75w90 being phased out for the 75w140? Does the front differential take the same fluid?
(and I ain't forgot about your other thread, gimme a few)
