Clogged up wheel wells!! SNARDS!
Ok here's the deal... Truck works great in the snow being only a 2wd. So that's not the problem. However, I am having a HUGE issue with snow getting stuck in the wheel wells. Now my queston:
What's the best way to clean them?
I've been using buckets of hot water and a plastic shovel with no sharp blades or edges. I don't want to mess my wheel wells up nor scratch the paint to rust.
Today it got soooo clogged up that the rear wheels were rubbing on the snow 1/2 way around the tire! I spent like an hour melting the snow just off the rear... the front was about the same!
My 1999 F150 never did this... there seems like there is more space to get more snow hung up.
If you move to Phoenix you wont have that problem. It was 85 deg. today!
Hey, thats not true. It's much hotter in Palm Springs, CA where I live. Try 135 one summer, taken at the weather station at the airport, which is up on the radar tower. Yeah, frying eggs on the pavement, flesh sticking to the asphalt kind of hot. But, I was born and raised here and I love it.
Originally Posted by SuperSport1985
Well why dont you go to the car wash joint where you can use a high-pressure wand with hot water, here in my town we have those so check around where you live. Also after you are done try to dry off your well wells and spray them down with tire dressing also works fine on your doors.
