Door noise
Old Feb 1, 2007 | 10:29 AM
uofmhockeyguy's Avatar
Door noise
Anyone else have an issue with the Scab front driver door making a rattle noise only when it is really cold out? I have a ’06 Scab and I am having this issue….had the same issue with my ’04 Scab.
Old Feb 1, 2007 | 10:38 AM
BestNTx's Avatar
put some acoustic dampner in the doors, behind the door panel. This should take care of all your rattles and road noise.
Old Feb 1, 2007 | 11:04 AM
FX4Firefighter's Avatar
i think i knwo what you are talking about mine has been doing it it sounds like tin hitting somthing i thought i was going nuts
Old Feb 1, 2007 | 11:33 AM
polo2005's Avatar
it might be because the back door on the supercab is not closed right, i know that it looks like it is but open and shut it hard and then shut your front door a little hard, that happened to me ones and that was the problem
Old Feb 1, 2007 | 12:23 PM
fx4fire...
yes..that is the noise, I thought i was going crazy too.
I know the back doors rattle a little if they are not closed all the way, but this is a very different noise...tin on tin is about what it sounds like...but only makes the noise when it is really cold out....very strange!!
Old Feb 1, 2007 | 12:30 PM
freddytran's Avatar
I have the same noise. It started after I installed the power windows. I know the one screw underneath the arm rest is loose so I think it's the door skin rattling. Because when I apply pressure to the door skin, it stops. Guess I need to pull it off. Maybe the screw clip is loose.
Old Feb 1, 2007 | 12:39 PM
styxnpicks's Avatar
my rattle is because I havn't got around to screwing in the last two screws of the crappy stock speaker
Old Feb 1, 2007 | 12:46 PM
05OVALOWNER's Avatar
A guy told me one time he was getting a rattle/squeaky sound out of his doors. He said that he used a little Armorall on the seals and the sounds stopped. I guess it would be worth a try. I have not tried this myself though.
Old Feb 1, 2007 | 08:30 PM
rob2004fx4's Avatar
I love these forums here, I have been hearing the same noise in my 04 scab the past couple of cold days too. Almost like a screw ticking in a cup. I'll turn up the radio till it warms uo some!
Old Feb 1, 2007 | 11:24 PM
bamorris2's Avatar
The left-rear door on my SCrew also has a creaking noise in the (cold) mornings. I've had the entire door panel off in search of the noise. I made sure everything was nice and tight. It didn't help... Thinking back to a previous 2001 F150 that I owned, one of those windows had a similiar creaking noise. It turned out to be one of the window tracks, down in the door. I think one of these weekends I'll take the door panel off again, and this time focus on the stuff INSIDE the door frame. The more I think about it, the more I think it's the same problem.
Old Mar 5, 2007 | 07:06 PM
welder's Avatar
My 06 supercrew drivers side door has made noises since day 1 and they can't seem to fix it.Sounds like the door isn't closed but it is.It is driving me crazy though.
