New instrument cluster???
Old Jan 25, 2007 | 10:08 PM
themetermcse's Avatar
just ordered the scangauge. pretty slick looking. I think I'll get some fiberglass molded to make it fit like an edge does or like a gauge pod above the radio.
as for the diablo, can't find one for the 2005 4.2 V6. Everything says the 2006 only.
Old Aug 20, 2007 | 04:48 PM
05F1FIDDY4x4's Avatar
Sorry to bring up old thread, but what did you end up doing about the STX gause cluster. I am getting tired of mine also.
Old Aug 20, 2007 | 09:18 PM
4x4whiteSTX's Avatar
i decided that installing a new guage cluster was a big pain and then bought a scangauge 2 and am glad i did, i ended up mounting it right below the windshield just to the right of the blinkin red light and ran the wires through the dash and the came out in the defroster area but you can even see then ill post pics if your interested...
Old Aug 20, 2007 | 10:48 PM
baja150's Avatar
Originally Posted by ChrisAdams
Well, this has been covered in very fine detail, every aspect. Search and Yee may find.
To just hit the high spots;
The cluster is easy to swap.
The mileage is contained in the cluster.
The 'new' cluster will work, i.e. gauges, cruise, speedometer, tachometer.
HOWEVER
The dome light, door chimes, headlight warning, alarm system etc. will NOT work until a competent dealer reprograms the cluster/PCM to match your truck.
This costs 45-130 bucks. Usually about 85 bucks.
The mileage will not match.
The dealership will almost never have the ability to adjust the clusters mileage.
Local speedometer shops may be able to do this. Price varies 70-299. Most pay about 85 bucks.
Legal stuff;
You can put in a different mileage cluster legally under very narrow criteria.
Example you can put in a 0 miles cluster anytime your cluster goes bad. This is federal and most states. BUT you must put a tag in the door jamb showing the cluster has been swapped and the relevant mileage change.
CarFax and other reporting agencies will note your mileage has changed. This dings your resale value.
Example, you take truck to dealer, tune-up shop, smog shop, get ticket, etc. anywhere that logs your mileage. Then you take it there three months later and it has less mileage... A red flag will go to CarFax etc. and from then on there will be a question about it whenever anyone looks at your vehicles history.
So get the correct mileage programmed into a cluster and then pay the dealer to set the cluster up.
Do the swap yourself if you like.
Unless you get one with the right mileage the extra cost drives the cost of a cluster swap up beyond practical in most cases.
Some of the vendors on e-bay can set mileage and include it with the cluster.
Chris
Great write up Chris... just wanted to add 1 piece of info to that. For those that have a 2006 or 2007 luxury package FX4. You can add a message center cluster like what comes in a lariat and everything will work 100% perfect. The wiring harness is even already there to plug in the messge center buttons.
... but the odometer will be off and you'll have to address that as Chris mentioned. I paid $100 to have mine programmed to the correct mileage and $20 for 2-way S&H.
Old Aug 21, 2007 | 07:12 AM
Could you post pics, that would be great. Thanks
Old Aug 21, 2007 | 08:43 AM
baja150's Avatar
Are you a member at Dezert Rangers?
