brake rotor replacement
Old Jan 1, 2007 | 12:58 PM
choi0706's Avatar
do we need to unbolt that HUGE nut in the middle?
Old Jan 1, 2007 | 01:08 PM
kd4crs's Avatar
I don't think so. Just remove the calipers and it should come right off.
Old Jan 1, 2007 | 01:39 PM
ochoada's Avatar
If you have 4-wheel drive then no...If you have a 2-wheel drive like me than yes you do.
Good luck
Old Jan 1, 2007 | 01:49 PM
kd4crs's Avatar
Right. Mine is a 4X4. I don't know about the 4X2.
Old Jan 1, 2007 | 08:41 PM
xlint1's Avatar
2 WD have a large spindle nut clearly marked, do not reuse. They are an OEM only lock nut and they run about $23 EA.
Old Jan 1, 2007 | 08:55 PM
Quintin's Avatar
On a 2WD, yes, and it must be replaced whenever it's removed. Torque to 295 ft/lbs with the new one.
Old Jan 1, 2007 | 11:19 PM
Redneck911's Avatar
You can find em for 16 bucks.
