anyone know how to disconnect the annoying sensor for the seatbelts?
Old Dec 17, 2006 | 06:01 PM
K1NGoftheRanch's Avatar
i drive from my house to town alot (1/2 mile) without my seatbelt...and sometimes leave it running when i hop out...that sensor drives me nuts...any way to disconnect?? thanks
Old Dec 17, 2006 | 06:02 PM
ThumperMX113's Avatar
Owners Manual. .
Old Dec 17, 2006 | 06:07 PM
Originally Posted by ThumperMX113
Owners Manual. .
seriously...its in the owners manual?
Yup.
Old Dec 17, 2006 | 06:10 PM
I just unpluged the harness from under my seat (just a single wire). But Do Not do this if you have one of those air bag sensing seats. That airbag might come in handy at somepoint
-Patrick
Old Dec 17, 2006 | 06:14 PM
whitecrystal1's Avatar
here is the way to do it...but you have to follow the directions exactly or it wont work...
The parking brake is set.
The truck/car is in Park (automatic), Neutral (manual).
The ignition is OFF.
All doors are closed.
The driver's safety belt is un-buckled.
The parking and headlights are OFF.
Then follow these 9 steps:
Turn the ignition switch to ON, but DO NOT START.
Wait for the safety belt warning light to go OFF(1-2 minutes).
Steps 3-5 MUST be completed within 60 seconds!
Buckle, then un-buckle the driver's safety belt 3 times, ending with the belt un-buckled.
Turn on the headlights, turn off the headlights.
After step 5, th e Safety Belt Warning Light will be turned on for 3 seconds.
Within 7 seconds of the safety belt warning light turning OFF, buckle then un-buckle the safety belt.
This will disable the Belt Minder if it is currently enabled, or enable the Belt Minder if it is currently disabled.
Confirmation of the disabling of the Belt Minder is provided by flashing the safety belt warning light 4 times per seconds for 3 seconds.
Confirmation of the enabling of the Belt Minder is provided by flashing the safety belt warning light 4 times per seconds for 3 seconds, followed by 3 seconds with the safety belt light off, then followed by flashing the safety belt light 4 times per second for 3 seconds again.
After confirmation, the deactivation/activation of the Belt Minder procedure is complete.
I tried that on my 05 and it didn't work...
what I did was:
Steps 3-5 MUST be completed within 50 seconds!
buckle and unbuckle 9 times light thn flashes quickly and within 7 secs buckle unbuckle one more time.
you gotta do that for each side too but it was the only way mine
Old Dec 17, 2006 | 06:17 PM
sterusmall's Avatar
Yep.
From the OM:
Deactivating/activating the BeltMinder feature
The driver and front passenger BeltMinder are
deactivated/activated independently. When deactivating/activating
one seating position, do not buckle the other position as this will
terminate the process.
Read steps 1 - 4 thoroughly before proceeding with the
deactivation/activation programming procedure.
The driver and front passenger BeltMinder features can be
deactivated/activated by performing the following procedure:
Before following the procedure, make sure that:
• The parking brake is set
• The gearshift is in P (Park) (automatic transmission)
• The ignition switch is in the OFF position
• The driver and front passenger safety belts are unbuckled
To reduce the risk of injury, do not deactivate/activate the Belt
Minder feature while driving the vehicle.
1. Turn the ignition switch to the RUN (or ON) position. (DO NOT
START THE ENGINE)
2. Wait until the safety belt warning light turns off. (Approximately 1
minute)
• Step 3 must be completed within 50 seconds after the safety belt
3. For the seating position being disabled, buckle then unbuckle the
safety belt 9 times, ending in the unbuckled state. (Step 3 must be
completed within 50 seconds after the safety belt warning light turns
off.)
• After step 3, the restraint system warning light (airbag light) will be
turned on for three seconds.
4. Within 10 seconds of the light turning on, buckle then unbuckle the
safety belt.
• This will disable the BeltMinder feature for that seating position if it is
currently enabled. As confirmation, the restraint system warning light
will flash 4 times per second for 3 seconds.
• This will enable the BeltMinder feature for that seating position if it is
currently disabled. As confirmation, the restraint system warning light
will flash 4 times per second for 3 seconds, followed by 3 seconds with
the light off, then followed by the restraint system warning light
flashing 4 times per second for 3 seconds again.
Old Dec 17, 2006 | 06:21 PM
-Patrick
Maybe pre-04 models but nope.
Old Dec 17, 2006 | 06:34 PM
Copenhagen848's Avatar
A great way to turn the seatbelt dinger off....is to buckle your seatbelt
Old Dec 17, 2006 | 07:29 PM
haha....i got it...I read the manual and went out to the truck and disabled that...along with the autolock feature...and set my pedals and seat to adjust when i unlock the truck with my keyless entry. i never read the owners manual when i get a vehicle as most dont tell you how to disable anything...(at least on audis and vw's) thanks again
Old Dec 17, 2006 | 09:24 PM
Really!? Thanks!
Old Dec 17, 2006 | 09:29 PM
Kool Aid's Avatar
Seatbelts save lives.
There is no credible argument that can be made for not wearing them, ever.
You can make all the idiotic excuses you want......but that's all they are.
:santa:
Old Dec 17, 2006 | 09:45 PM
:santa:
all true....but how annoying is it when you or your wife/gf whatever...hops out of the car while its still running and a few seconds later that dinger is going off...was driving me nuts...another reason i wanted it disconnected
Old Dec 17, 2006 | 09:53 PM
Seatbelts=good, extra overly agressive and super-loud dingers=bad.
Old Dec 17, 2006 | 10:20 PM
