Looking For A Reference
Originally Posted by 2Brak
Stealth, as I previously asked, reference a shop to me that will remove them.
Yeah, you'd think in LA, California I could find someone to do it, but so far haven't. On a side note, you're truck looks great, and I know Bell Tech has been a round for a long time, great product.
2Brak, there is a very easy way to take out your rear blocks, and all you need is a floor jack and a rachet and socket or wrench to fit the nuts on the u-bolts.
1. Park truck on level ground and block front wheels
2. Crawl under and remove the 4 nuts, axle plate, and 2 u-bolts from one side of truck
3. Place pad of floor jack on leaf spring as close to axle housing as you can get and jack up truck high enough to pull out block. (you want to jack up truck and spring, NOT axle)
4. Lower truck back down so spring sets directly on spring perch on axle and the pins drop into the holes.
5. Install shorter 2WD u-bolts, axle plate, and nuts.
6. Repeat #2 thru #5 for other side.
7. Optional, replace rear shocks with shorter 2WD shocks.
