Edge Trouble with 4WD
Old Nov 27, 2006 | 11:08 PM
CANNONFX4's Avatar
Exclamation Edge Trouble with 4WD
I know I said I wasn't going to be mudding with my new truck, but I couldn't resist. Overall, I thought it handled pretty well offroad, but i felt like my old 2500 was more solid (which I would expect from a HD).
Anyways, I went into 4 low to get up a steep and slippery hill. When I first took off the truck kind of surged a little bit and then worked fine the rest of the way. After getting to the top I went into 4 high and fooled around in some mud. Went back into 2 high and hit the pavement. I didn't notice it at first because I was going slow and letting my lugs clear, but when I accelerated, the truck began shuddering real bad and the wrench light was on.
This happened befor when I first went to level 3 with the Edge. Just like I did then, I went back to stock and then reloaded level 3. Now the truck takes off fine. Maybe I need to check for an updated version. It just seems like it was caused from using 4WD. Anyone else have this happen?
Old Nov 28, 2006 | 12:51 AM
JonF150's Avatar
I haven't, but I haven't done serious offroading, just enough to stay unstuck around the deer ranch...
Old Nov 28, 2006 | 10:24 AM
nuclearthreat54's Avatar
Did you shift in and out of 4low correctly?
Old Nov 28, 2006 | 11:34 AM
weaseled's Avatar
Next time, if there is one, pull the codes. If the wrench was on there should have been a DTC. Mine, occasionally, does the same thing when I REALLY get on it while pulling someone out at the beach. I don't think it's 4WD related, because I use mine on a regular basis -- no less than once weekly.
I don't remember what DTC's it was throwing tho...
Old Nov 28, 2006 | 12:14 PM
CANNONFX4's Avatar
Yep, I went to neutral then hit the switch and waited.
I tried to read the code but it said it was unknown. It wasn't just when I really pushed down, it just seemed like it didn't want to get up and go. When I pulled over and reved the engine it did the same shuddering feeling, so I guess it is something wrong with the info the computer is sending the engine.
Old Nov 28, 2006 | 12:19 PM
weaseled's Avatar
That almost sounds like the truck went into limp mode. When mine does it on the beach there is no difference in drivability. I just cannot get rid of the code without reloading stock...
My truck felt exactly like you're describing when I was messing around with my speedo. The truck sensed it was going way to slow -vs- RPM and went into limp.?
Old Nov 28, 2006 | 12:26 PM
CANNONFX4's Avatar
That sounds like a good explanation to me. I am going to update my software and give it another try. Thanks.
Old Nov 28, 2006 | 02:38 PM
Adam06FX4's Avatar
Registered User
update the edge.
