Where do you purchase your lift kits?
just like the title suggests. where's a reputable place with good prices?
also, i don't want this to turn into a fabtech vs. Rize debate. i know the rize is badass, but for a DD that won't see anything offroad besides the odd sand dune or light duty trail, which is better. i read something about the fabtechs and the steering rack that the Rize corrected, but is it an issue for a non offroader? i want to clear 37's with little or no rubbing. thanks. |
then deffinatly go with the rize if you want 37';s and little or no rubbing
i have the rize and 38's and have some rubbing when turned and bump.... |
Rize 8" without a doubt. :beers:
rize 8" lift if u want little or no rubbing with 37's
holy $h1t the rize is expensive. $2600????? but damn it's sweet. maybe a fabtech with coilovers cranked and an AAL for the 37's?
for the price I would also check a local suspension shop. They usually have them cheaper since you dont have to pay shipping. |
Someone buy me a fabtech.. Secret Santa or something.
sooo..for a mostly street truck, would there be any disadvantage running the fabtech? that is, from a purely mechanical/functionality standpoint.
pro comp with coilovers 2000$ on 4wheelonline.com
im buying that im tired of shoppig for lifts this site is giving me the bug...... i really have to stop coming in here....... all my $$$$$$$$$$$$$$$ is going out the window.. lol also ive seen 37 on the 6 inch procomp with coilovers maxed out.. i think it gives you like 1 inch more? if not mistaken......... |
Go with the Rize, the ride on the street is supposed to be great. With DL coilovers the ride is ok on the street, I still need to fine tune the pressure inside the cylinder (very small), a quick release of air will drop it 10psi.
There is a good bit of trimming to fit 37's, but don't let me discourage you. I am probably going to install a 3" body within the next month or so...this'll be fun. Also considering a supercharger right now, just need a good local tuner. Have an old dyno shop I worked with who might be able to help me out there. |
maybe i'll suck it up and get the Rize then. I couldn't find the price of the AAL's for the fabtech online, but I'm sure they're a couple hundred. combine that with the Fabtech and DL coil overs and it's only a little more for the Rize. I'm looking for a truck right now and want to find all the parts for the lift that i want to do. I'd rather not cut up a new (to me) truck anyhow...
also, anyone got a line on Weld wheels? jut curious what the average 20x10 would run.... edit...n/m just found them on discount tire. $500/wheel is insane. i'll stick with the Hulks or 951's. (i know, i know) but at least they're not 2K for the set. |
When it's all said and done, you are better off getting the Rize instead of trying to turn a 6 inch lift into an 8 inch. At first that was what I was going to do, but the Rize just solved all of the problems. Plus, you are correct, the steering system on the Rize is great.
