edge guys
Old Jul 6, 2006 | 06:29 PM
sparkysvt's Avatar
edge guys
thanks for all the info that lead me to buy it. i got it today and installed int right away. then me and my pops took her for a run on lvl2 with 87 in the tank and wow. it really woke her up. the shifts are very noticeable but not really aggressive. so anyways it's set on level 2 for now, and then i went into the custom option and changed my tire size as well as gear ratio and speed limiter. i bumped the speed limiter to 105 since i have the tires from the factory still on it. what i found is that the tire size that was already in there was much higher. it was like 29xx and my tire is a 2398, also when i changed the ratio it was set to 3.73, not 3.55? could this be defualts on the edge, defaults on the ecu, or did my truck possibly get programmed wrong from the get go ?
Old Jul 6, 2006 | 06:31 PM
sparkysvt's Avatar
another question, everytime i start it it ask me if i agree to the terms or whatever? will it always do that? and do i have to re-flash the pcm everytime it asks me this ?
Old Jul 6, 2006 | 08:40 PM
SVT Pilot's Avatar
Sounds good! It doesn't require you to run premium gas w/ level 2?
Old Jul 6, 2006 | 08:51 PM
SnowmaNick
Guest
Posts: n/a
As to thee warnings if you look on the bottom it says 3 remaining, 2 remaining, once your done you are good until you remove the code and put it to stock and then start over.
As for the tire size and gear ratio I have heard both that it reads what the PCM currently states for the tire size and gears and then the opposite, that it has defaults that you have to change. I personaly just change it and save it so I know it's right.
Congrats on the purchase.
Old Jul 6, 2006 | 09:07 PM
sparkysvt's Avatar
hey man did you ever get some pics of your fan setup? if so can you post them or email them to me. the flx-270 is the kit im purchasing and having the local speed shop wire em up.
Old Jul 6, 2006 | 09:30 PM
expy03's Avatar
Level 3 requires premium. Level 2, is ok with 87.
