Highway and gears???
k so the situation: 4.56 gears front and rear
5.4L V8
8 inch lift with 38 tires
85-90% highway driving
driving around 72-80 MPH 90% of the time (thats how people drive here in GA
so....hows my mpg going to look.....i will have a edge tuner on it. should i go to just 4.11 gears? or what?
60 bucks to fill up my tank here
5.4L V8
Find out how much your tires weigh and that will better help answer your question. I am going by tire weight and revs per mile. Your gear ratio is going to be very low with 38's and 4.10's (might as well stick with 3.73's, not going to be a costworthy difference on a 4wd). If your tire/wheel combo is lighter than mine (willing to bet they are by a long shot) then if you use cruise at low speeds 60mph you'll see great mileage. Definitely hard to say even if I knew your tire weight because I can't say with the mods you have.
My recommendation: Wait until you drive with 38"/3.73's (the added truck height might overshadow the tire weight arguement I had) because height is a variable that really messed with my mileage, much more-so than tire weight. Definitely do not throw 4.56's in there if you do 90% highway driving before trying 3.73's.
thanks josiah alwasy a help. well....the tires shipped had a total weight of 392....so that makes it 98 pounds a tire....around 20 pounds per wheel. so thats say 120 without air. how much you think with air would weigh??
well....have the money at the time to do gears...(parents are paying for all installation i just bought all the parts) but im tyring to find out if i should or not. every weekend ill be making a 70 mile trip down to where i use to live (35 there....35 back) to see friends.
how much did you say your tire/wheel combo weigh?
it should be done by...im going to say july 20th.
still need to sell my Pro Comp Kit and buy the Rize.
well i have the....27 gallon tank....its only like....2.85 here...i tohught we had it bad....
