F150online Forums
F150online Forums (https://www.f150online.com/forums/)
-   2004 - 2008 F-150 (https://www.f150online.com/forums/2004-2008-f-150-80/)
-   -   5.13's on stock rubber? (https://www.f150online.com/forums/2004-2008-f-150/243390-5-13s-stock-rubber.html)
styxnpicks Jun 14, 2006 11:16 AM
anyone running higher gears on tock rubber? I'm not happy with how long the gears are with the 3.73. I'm also not really into top speed (altho I'd like to be able to go 120) my main thing is acceleration. so I'm thinking about 5.13's since I do very little highway driving. (I'm always doing 100 if I'm on the highway anyway) so mpg isnt a concern at all
extremeethan Jun 14, 2006 11:26 AM
Are you kidding? 5.13? I dont mean to be rude but dang.
styxnpicks Jun 14, 2006 11:30 AM
hell why not? It would actually make my 4th gear (od) usefull since I drive with it off all the time anyway (even on the rare highway trips)
05supercrew Jun 14, 2006 11:35 AM
Get the 4.88s you will be more then happy with that.
styxnpicks Jun 14, 2006 11:57 AM
the diff between 4.88's and 5.13's @ 65 is only 200 rpms. the funny thing is the way i drive now with the od off all the time I'd atually be able to drive 200 rpms lower with the od on with the 5.13's (can you tell I'm trying to build a sport truck)
05supercrew Jun 14, 2006 12:04 PM
Not a big difference at all, its up to you. You stated before when your on the highway you go 100 mph. Whats the difference at 80 mph? I personaly think its a lot of gear for stock tires.
Josiah Jun 14, 2006 12:51 PM
Talk to bhf150, his name is Brian. He's running 4.88's on stock rubber and a procharger setup. I've been in his truck but have not driven, he'll be able to tell you more.
05supercrew Jun 14, 2006 01:04 PM
In that case go for it. Definitly do a little write up on how the truck performs.
texxx150 Jun 14, 2006 01:13 PM
Unless you have a 4.6 and the 8.8 rear end, they don't make a 5.13. 4.88 is as high (low) as you are going.
styxnpicks Jun 14, 2006 07:20 PM
I was under the impression that all the F150's with 3.73 or 3.55 gears had 8.8 rear ends. and only the 4.10 being a 9.75
Screw2004 Jun 14, 2006 07:37 PM
4.6 = 8.8,5.4=9.75 and the 5.4 with hevayduty package i believe gets 10.25
styxnpicks Jun 14, 2006 07:49 PM
would I be crazy if I swapped my buddy rear ends? he has the 4.6 w/ 3.55LS and I have the 5.4 w/ 3.73 LS. I don't have any plans to tow. where he tows his bronco every weekend and wants the 3.73's (I actually talked to him today)
Screw2004 Jun 14, 2006 08:12 PM
Put down the crack pipe..are you insane..get the gear's..I am runing 4.56 with 33" and turn 2000 rpms @ 70:beers:
styxnpicks Jun 14, 2006 08:14 PM
lol, I'm asking If I would be crazy to swap my 9.75" 3.73 for my buddies 8.8" 3.55 just to regear the 8.8" to 5.13
(I should have just bought a damn lighning in the first place)
Screw2004 Jun 14, 2006 08:18 PM
Thats just nuts...Dont do it I repeat do not swap out 9.75 for a 8.8..get the 4.88's I am sure you could get some custom cut gears also:thumbsup:
