Harley Pedals installed
The gas pedal has an electric plug, and 3 bolts it was easy. The brake pad is a cover... it was an SOB to stretch and fit on. I ended up using some liquid soap and it made it easier. The emergency brake was a similar deal slide on and insert this fat rubbber **** into a hole on the pedal. Over all though, simple install....
odd. I thought the brake pad had to be the entire assembly. Lets here some part numbers and prices!
Duke
Duke
part numbers/prices
FordParts.com
The gas pedal is a complete assembly that you swap out (3 bolts)on the back of the fire wall. Like I said the other two are pads you swap out. They are metal though. As soon as I pulled them out of the box there was an "ooooooo
" factor. Nothing like the feel of OEM....
Part Numbers are as follows:
Gas Pedal (Assembly) 6L3Z-9F836-CA $91.32
Brake Pedal (Pad) 4C3Z-2454-AB $ 28.58
Emergency Brake (Pad) 6L3Z-2454-AA $17.76
$151.43 shipped fordparts.com
" factor. Nothing like the feel of OEM....Part Numbers are as follows:
Originally Posted by lawclerksfv
It is definately an aesthetically pleasing mod, just a bit pricey for some of us.
They look good man but yes pricey. I paid 40-45 clams for my 3 pc billets(there like the Steeda ones) and I am very happy with those but kind of a pain drilling in the brake and e-brake. I had them in my Mustang and Lightning as well.
But as I said yours look good also man keep spending
