New Whipple Numbers... it was a little hot out though. :)
Wow, here's an old thread. This was before I had the dyno sheets, the numbers were actually 426-427RWHP and 469-474 ft/lbs of torque in 99 degree heat.
The higher the octane, the better the truck will run, up to around 95 octane. The 91 was limiting me, but not as bad as the premium back in Alaska, which is 90. I am going to mix racing fuel with premium next summer to get 92 octane which will help out some. The computer will relearn the new octane and automatically add timing back in. I also just got a delta programer that I can manually adjust spark/timing, tire size, gear ratio's etc. I need to get a wide band air/fuel meter so I can keep track while I'm toying around with it.
I was hoping to get some new pictures, but we just got a bunch of snow, which turned to slush, which makes the truck seriously dirty.
As for quarter mile times, hopefully next summer I will get that. There is a track about 300 miles from here that I'll try and get to. I'd be happy with 14.0-14.5 times, and tickled with anything in the 13's.
Originally Posted by etrevino103186
awesome numbers. what do you think you are producing at the crank?
