Oil Consumption
Old May 9, 2006 | 11:56 AM
pldjr0187's Avatar
Exclamation Oil Consumption
The dealer did an oil consumption test on my 2005 5.4
I've used about 2 quarts of oil In 2,400 miles. I have 15,000 miles on the truck now. I use ford oil and filter only.
Still waiting for the dealer to get back to me on a decision.
They have change the pcv valve, No help.
Just wondering if anybody else is having a problem with there oil, or any suggestions that I can pass on to the dealer.
Any help would be great.
Old May 9, 2006 | 11:59 AM
That would make me ill. Sorry to hear you are having that problem. I go 3500 miles between oil/filter changes, it just barely moves off the full mark. I have 25,000 miles on it.
Old May 9, 2006 | 12:05 PM
05supercrew's Avatar
They are going to tell you that its normal. I just got back Saturday on a 7 day vacation with the family and put 3k miles on my truck and didnt burn any oil. Do you have a leak?
My dad has a 1999 f250 crew with a 5.4 2 valve, anyway we had to make a trip to central city KY to bury my grandma when the truck was less than 4 years old, anyway on the way back the oil light came on in the middle of nowhere at like 2am, freaking us out. We had eventually found a store and put in some oil. The dealership said the 5.4 2v engines burn alot of oil. I don't know sounds wierd to me.
Old May 9, 2006 | 12:18 PM
pldjr0187's Avatar
No leaks, no oil on driveway and dealer said they found none either.
Old May 9, 2006 | 12:32 PM
FX4_Guy's Avatar
I go almost 5,000 miles between changes. At the end of 5,000 the oil is sitting on dang near the exact same spot as when I changed it. No oil burn whatsoever.
Old May 9, 2006 | 12:36 PM
SnowmaNick
Guest
Posts: n/a
I only have just under 6K on mine, but just did the second oil change. I didn't have any noticable burn, so it's not that the engine burns more when new, if they try to pull that BS out on you.
Old May 10, 2006 | 05:48 PM
pldjr0187's Avatar
Went to dealer today. oil down an half of quart of oil in about 500 miles.
Dealer changed oil. Manger said he would put together a report and call ford and see what they want to do.
Manger said he has never seen a 5.4 used oil.
So I guess I'll wait and see what happens.....................
Old May 10, 2006 | 06:25 PM
I hope it all works out for you. I hate it when a major investment like a truck goes bad like that.
Old May 10, 2006 | 06:53 PM
BennyHanna's Avatar
Ditto.... mine doesn't drop at all.
Old May 10, 2006 | 07:13 PM
worland's Avatar
I've never seen a 5.4L use that much oil either.
Typically they won't touch an engine using less than 1 quart every 1000 miles. You're right on the border line of acceptable oil consumption. Hopefully they'll fix it.
Old May 10, 2006 | 07:37 PM
MosineeFX4's Avatar
I traded my 99 in on the 04. It had 139,000 miles on it and I never once had to add oil in between oil changes. I have 22,000 on the 04 and I have not ever had to add oil to that either.
My Toyota Camry on the other hand, that thing uses a quart every 1000 miles.........POS.
